I've been following the various 'suspension' and 'shock Absorber' threads, looking for answers. Got a R32 GTSt with ride heights of F/R 350mm, Left 350.5mm, Rear Right 345.5 and Left 350mm. The front , both sides. but worst on Drivers side, bottoms out hard over pretty minor road irregularities. Shocks are Bilsteins and seem quite firm, and no rebound when pushing down on front of car. Can only think that bump stops at fault. Can anyone tell me their stock height, or thickness or whatever?
Edited by Jax
https://www.sau.com.au/forums/topic/179351-bump-stops/
Can anyone suggest how I might turn this from a simple question into a complicated one, where there might be dozens of possible answers? Everyone seems to have a go at the hard ones. This is just too dull, just wanting one little measurement??
https://www.sau.com.au/forums/topic/179351-bump-stops/#findComment-3278779
    • Yep. And if you ever do, you'll just have to deal with it then.
    • E10 is pretty tightly regulated in percentage. Too much and engines can't adapt. Every incentive is against them to have too little ethanol though. The more ethanol the higher the octane.
    • Yeah i have R34 with factory small box and now RB25DET NEO swapoed and iam planning to upgrade to big box.  So i would be good as long as i do not change diff?
    • Based off what you’ve said here, I think I’ve figured out a good bit of what I’ve done wrong -  So on the line going from the PCV valve to carbon canister, there’s a T joint that is pretty much right next to that lower port - I hadn’t noticed that the hose in the diagram was curved to attach onto the carb, so I was putting that line for the lower port onto the PCV line / carbon canister line instead. I’m going to have a flick through the manual again tomorrow and should hopefully find a diagram that’ll show me where that T joint should be connected to. Timing also 100% needs to be sorted out as well, should be able to tackle that tomorrow as well. Definitely feel like I should be on the right track now though.
