Can be done but it's dodge.
Reasons against:
Uneven fuel distribution to each cylinder
Hard to tune for
Unroadworthy modification
Injector seating issues as there's rail to bolt them into, dangerous if not done properly.
Fuel reversion issues during gear changes when changing gears, extremely dangerous if using atmo BOV.
Looks like puss
https://www.sau.com.au/forums/topic/179361-extra-injector/#findComment-3268647
fair enuff! thought there might be a few reasons againt it. how do they get away with running them on rb30s so sucessfully then? or is it just because they are VL drivers that they harp on about how well they work>?
cheers!
brett
https://www.sau.com.au/forums/topic/179361-extra-injector/#findComment-3268664
cheers!
brett
It stems from VL racers in the 90's using hobs switches etc, hence they still talk about it as it was common among them back in those times and some still today.
And then it got a little more upmarket with microfuellers to control them.
Usually boost or throttle body position activiated, and then RPM with micro's
Basically to get around the fact no-one wanted to pay for management & injectors but still want some performance increase.
It does work, but in 2007 when management and injectors are so cheap and legals have more issues than ever... why would you bother?
https://www.sau.com.au/forums/topic/179361-extra-injector/#findComment-3269351
another thing thats popped to mind was how they used to compress the tops of their standard fuel pressure regulators to bump up the fuel pressure up by around 15-20psi.
there was a way of doing this by T'ing the FPR to a compressor, run it so it shows the psi then compressing the head of the FPR and you'd actually be able to see what pressure you'd be bumping it up to.
again, im not sure how reliable it would be.
https://www.sau.com.au/forums/topic/179361-extra-injector/#findComment-3269359
Not only with the vl boganadores. The japs used to use extra injector controllers. I've seen numerous cars with an injector or two in the intake piping.
It's not such a big thing nowadays. With the price of injectors, the hassle isn't worth it for me - looks dodgy. Back in the days, there wasn't such a large range of a/m injectors
https://www.sau.com.au/forums/topic/179361-extra-injector/#findComment-3269735
  • 1 year later...
im thinking of dropping in an extra injector (2 actually) thru the stock intake piping
found a used kit in japan includes 2x 700cc sard injectors on the stock rb25det intake pipe
would it be better to flog these 2 injectors off and use 2 stock 5b25det injectors (2 + 6 stock) ?
reason I bring this up, doing some head work last thing to get is the tomei poncams - pretty much a full hiflow rebuilt head with gaskets etc, but stock stnd bottom end.
with the poncams and the headwork Id dare say the stock 6 injectors would be at the 228kw full load mark - hence an extra bit of fuel.
hopeully 2 extra injectors (stock size or the 700cc sards) would allow enough fuel to use the poncams properly
using a remapped ecu chip from Toshi (long distance tune) + safc/sitc + adj.fpr/adj.camgear&poncams + z32afm/full intake-exhaust-cooling mods etc etc,
with the kit Id expect my engine would therefore be tuneable to a point past the 100% load useage mark for 6x stock injectors, instead of being set for a max of say 220rwkw and thats that (without muckn around with new ecu remap chips + bigger injectors), perhaps 240rwkw is possible?
thoughts?
head work includes tomei lifter kit, tomei poncams and oil restrictor gallery, infinity 90mm throttle body with greddy adapter plate, rb25 cometic head / exhaust / intake / collector & manifold gaskets, clear timing belt cover, epp valve seals, valve guides & seats for exhaust/intake, head stud kit, plus the rebuild work by a local shop - including touching up the porting etc
https://www.sau.com.au/forums/topic/179361-extra-injector/#findComment-4196352
got the adjustable Nismo fpr, had that for a few years now, and it gets adjusted with the tunes
mainly looking at this as a way to reach max efficiency for the hiflow turbo (ie 245rwkw), with the head work etc the Stagea should be pretty awesome
can make up a metal box to cover the intake injectors to make it look stock :D
https://www.sau.com.au/forums/topic/179361-extra-injector/#findComment-4196476
showing how NUB I really am - how will the tuners set up control for external injectors?
whats needed to run them, thru a remapped ecu + safc + sitc + adj.FPR ?
Is there a brand name extra injector electronic module available from japan (old-skool, ie ebay/yahoo) that can be bought, installed and setup?
this is the stuff Ive got ready to go:
Cometic intake manifold gasket
Cometic intake collector gasket
Cometic exhaust gasket
Cometic Head gasket 1.2mm x 87mm
ARP head stud kit
EPP 6mm Intake valve seals
EPP 6mm Exhaust valve seals
EPP Intake valve seats
EPP Exhaust valve seats
EPP Intake valve guides
EPP Exhaust valve guides
Q45 90mm throttle body
Greddy Q45-RB25 adapter kit
EPP clear cam gear timing belt cover
Tomei oil gallery restrictor orifice
Tomei hi-lift valve springs ~8.8mm
Tomei 256/256 pon cam shaft set
2x 700cc Sard injector external intake manifold setup
https://www.sau.com.au/forums/topic/179361-extra-injector/#findComment-4198763
The problem is that you need to switch the additional injectors on and have the ecu tune change at exactly the same time every time, otherwise you end up with a lean hole or rich spot, neither which is good for the driving pleasure or engine longevity.
https://www.sau.com.au/forums/topic/179361-extra-injector/#findComment-4199819
you can either use a micro fueler - a separete lil computer to control it, or a hobbs switch - a switch the sees pressure and closes two contacts, think of it as a boost activated relay. some people feed 12V straight to it but another way, which has more risks, but will give a better result, is to take the + off another injector and use that as the feed to the hobbs switch
these are the two common ways, there may be more though
Edited by VB-
https://www.sau.com.au/forums/topic/179361-extra-injector/#findComment-4199828
cheers, Ive been looking into indepedant fuel injector controllers
will keep on looking into it, get all my info and gear sorted, then hit up the tuners for the head (then see the flow specialist) then back for the head reinstall and tune of everything
https://www.sau.com.au/forums/topic/179361-extra-injector/#findComment-4202443
I just finished removing the extra injector set up (originally had 2 extra) from my car yesterday. Personally having run it in the past i wouldn't recommend doing it even when set up correctly (mine was part of the GReddy kit) it was a right pain in the arse.
Controlling mine was done with a REBEC 2 and you could set the duty & gain along with the rev range/cut. For an older bit of gear it was ok and did the job but not upto my standards hence getting rid of it all and just running 6x555s instead.
Put it this way, im about to through it all in the bin thats how much i wouldn't recommend it to anyone else or on sell it all ;)
https://www.sau.com.au/forums/topic/179361-extra-injector/#findComment-4202527
