awesome photo's TurboX. Amazed that you took photos and drove haha
Missfiring car (could be ignition module) + vibrating steering wheel (wheel balance) + car pulling to the left (wheel alignment) wasnt very fun to drive and wasnt keen on pushing it. Hence i was left off somewhere in the back haha
I think at one point i would have missed a turn if TurboX didnt slow down for the turn, not sure if that was intentional or not but you saved me getting lost (again) cheers :)
looks like a good cruise. I was planning on making it but, at least i've got a good excuse!
just came back from Adelaide with a new addition to the family :)
for me was a long cruise, but pretty boring with all the highway piggies around :)
Hey Mav, did your car make it all the way home without any dramas? :)
Ummm i think i'll go with no comment :)
I know where i need to make some changes to my cooler pipes lets say that but hey it would have looked NUTS shooting fireballs :)
Changed my plugs when I got home... might explain the misfiring problem
Shit, brings back bad memories... :thumbsup:
Looks like a great cruise, any cruises organised on Sundays???
Some people have to work 6 days a week you know!!!! :rolleyes:
Mav, the work wagon it was.. :-)
Patrick , if you mean the last turn almost to go up the mountain, your right - I would not have realised either, so hung back for you.
BTW you were not doing to bad, you kept up to me, but I was having trouble keeping with Tharaka! :rolleyes:
Some more memories..
BTW you were not doing to bad, you kept up to me, but I was having trouble keeping with Tharaka! :ph34r:
haha ye i noticed that, thanks for that :rolleyes: Car couldnt be pushed due to missfire+wheel alignment :)
Your new car has some quick acceleration there, noticed it in a few places where you pulled away quick and left my rb20 in the dust :thumbsup:
Yeah its amazing the difference I notice with my GTS4 between the RB20 Torque Miser and the AMG V8 5.5 Torque Monster! :thumbsup:
If you have to compromise with the missus, its the way to go!
Especially the fact its silent and she doesnt notice the speed near as much! :)
Last of my pics....
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
