PRICE DROP Prices below!
R33 GTR Coilovers Eibach Springs $1200
R32 GTR Diff with axles $600
Wheels $1600
Front mount $300
R33 Steering Rack $150
R32 GTR Diff With drive shafts was on a R33. $800
Apexi Coilovers $ 1800 came off a R33
Good condition
Not sure of the KMS, or spring rate these are externally adjustable damper.
All parts ready to be picked up from hornsby
17" final speed Forged Light weight wheels. $2000
17, 45, 255 Rear
17, 45, 235 Fronts
R33 GTR Front Mount Black in Colour $500
600*300*92
Steering Rack $150
4 Rotors Disc's $100
All prices are Negotiable
Thanks
Geoff
Edited by Geoff897
The Coil overs.. They look like they are for a GTR? is that True? Or am i wrong?
Coz R33 GTST and GTR use drifferent suspention
It was a R33 series 1 Gtst that the coilvers were in. But i will confirm with someone tomorrow.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
