Guest V8r31Skyline
Question to Skyline enthusiasts, this may be a first but am having a few probs as i have just bought myself an R31 with a 308 donk and turbo 400 3speed trans, first major prob is vibration from the tailshaft and/or diff and yoke ,which would be the major cause of this be? as it still has the standard split tailshaft but there is more than an inch from the rear of the gearbox still uncovered. Next is just a minor prob ? is it correct that the instrumental panel ie speedo electronic and can it be run manually through cable speedo ?????? Help Me , once this baby is on the road properly and exterior is taken care of it shall be on the road ready to race all you other enthusiasts , previous records of this car down the quarter are 11.4 which it ran 2 months ago at willowbank
https://www.sau.com.au/forums/topic/17941-electrical-hiccups/
stock tail shaft?? dodgy CV joints usually cause vibrations. some ppl get a one piece for their r31s
the trans speed sender (also used by the ECCS for things like determine if to clean the AFM wire after a drive) might be able to be connected somehow where the normal cable in the other trans would to use the stock electronics speedo. but id imagine you'd have to gear it right to get it accurate
