Well, I'm doing my first oil/oil filter change, and managed fairly well until i removed my oil filter, and oil just PISSED everywhere from the filter. I'd had the oil draining for about 30 mins, do i have to drain longer? Now i have about a cup of old oil over my garage floor... :rolleyes:
S2 Stage (RB25DET NEO)
https://www.sau.com.au/forums/topic/179454-changing-oil-filter/
I always spill heap of oil but i use a tray to catch it , it works better than the floor
Yeah i had a tray, but didn't quite expect another cup or so pissing out when i removed the filter. Also because the filter is in sideways that's why. Just wished it didn't get all over my nice clean engine (f^*k the garage floor!) :laughing-smiley-014:
Draining time has nothing to do with oil filter oil. The filter has oil in it. After you do it a few times, you'll learn to anticipate where the oil comes from etc.
I normally do the oil/filter without dropping a single drop on the floor. Put some cardboard down for safety anyways.
I use rags and carefully stuff them in under the oil filter. They obviously need to be right up against the block so they're under the end of the filter. Sometimes you will have a little spill but the rags soak up most of it and keep things fairly clean.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
