Well, I'm doing my first oil/oil filter change, and managed fairly well until i removed my oil filter, and oil just PISSED everywhere from the filter. I'd had the oil draining for about 30 mins, do i have to drain longer? Now i have about a cup of old oil over my garage floor... :rolleyes:
S2 Stage (RB25DET NEO)
https://www.sau.com.au/forums/topic/179454-changing-oil-filter/
I always spill heap of oil but i use a tray to catch it , it works better than the floor
Yeah i had a tray, but didn't quite expect another cup or so pissing out when i removed the filter. Also because the filter is in sideways that's why. Just wished it didn't get all over my nice clean engine (f^*k the garage floor!) :laughing-smiley-014:
Draining time has nothing to do with oil filter oil. The filter has oil in it. After you do it a few times, you'll learn to anticipate where the oil comes from etc.
I normally do the oil/filter without dropping a single drop on the floor. Put some cardboard down for safety anyways.
I use rags and carefully stuff them in under the oil filter. They obviously need to be right up against the block so they're under the end of the filter. Sometimes you will have a little spill but the rags soak up most of it and keep things fairly clean.
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
    • Downshifts are harder on transmissions than upshifts, the input shaft naturally slows down once disconnected from the engine so the synchros aren't doing all the work. There's no "natural" tendency for an input shaft to increase RPM. Something is not right there, I don't have a great answer on what. You can try a dedicated GL4 75W90, I plan to switch to Motorcraft XT-M5-QS which is supposedly a very good 75W90 for NB Miatas which have a weirdly sensitive transmission from the factory. I would chase down why your clutch is making a hissing noise, that's not normal. It might be no big deal but in the absence of anything else to investigate I would look at that.
