my headlight indicators seem really dull
the glass was pretty murky, so i gave them a polish
much cleaner looking, but unless it's night time or an overcast day the actual indication is almost invisible
- so, i guess it's also kinda dangerous
had a few people pulling angry tard faces at me recently because "i wasn't indicating" so i was wondering is you guys had any ideas what the issue may be?
...bad wiring?
...time for new light units?
...is it maybe possible to install some indicators on my frontbar?
BTW:
don't mean to cover old ground
i have read quite a few topics already up, but unhappy with info found
https://www.sau.com.au/forums/topic/179466-33-headlights/
Just buy LED Orange Indicator bulbs, should shine straight through the cover, even if it is Dull, best way to go I reckon..instead of spending heaps on modifying your front bar to fit indicators..just spend $7 for the bulbs..
https://www.sau.com.au/forums/topic/179466-33-headlights/#findComment-3270509
whilst we are on the topic of r33 headlights...
i bought some bulbs from supercheap auto and im getting complaints from ross that they are way too bright when im driving behind him.
they are 55W bulbs - what is the W that an R33 is supposed to have?
they are the white- looking lights.. i forget the brand name n stuff, but i still have the box in the car.
https://www.sau.com.au/forums/topic/179466-33-headlights/#findComment-3270905
haha you got the same problem as in Lucy, friends always thing i have highbeam on when im behind them, but yeah i changed the angle of the bulbs so shines down abit so yeah not into peoples eyes anymore..and yeah there 55W..
stock was 55W..didnt shine lik high beam
new ones 55W..shine like high beam :S wierd..
https://www.sau.com.au/forums/topic/179466-33-headlights/#findComment-3271910
thanks man, i'll look into it
https://www.sau.com.au/forums/topic/179466-33-headlights/#findComment-3272518
  • 4 weeks later...
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
