Hey guys,
Bought a set of rims not too long ago second hand very cheap with the understanding one of the rims needed repairing because it had severe gutter rash and a small buckle, so i had that one fixed ($120) and now have gotten round to removing the tyres off the other rims only to find another rim has a smaller buckle, i'm just wondering whether this will affect the handling etc of my car once the tyres on it and whether it's dangerous, i will get it repaired if necessary but just wondering if anyone can shed any light on the situation, i've attached pics
Cheers
https://www.sau.com.au/forums/topic/179471-slightly-buckled-rim/
i would have it looked at, because if it is out of round it will vibrate and cause unwanted shuddering at certain speeds. i had a set of 18's on my old vs commodore that i bought second hand, they didnt look stuffed or damaged so i ended up getting new bushes ect. thinking it was everything but the wheels causing shakin, so i took them to a wheel specialist (any place like bob jane, beaurepaires ect.) and they put it on the wheel balancer and told me it was slightly out of round, so i took it to bob jane they sent it away... got it back and well... i dunno if it was fixed or if it was the other rim on the other side... i even changed them all over but was still shakin, ended up puttin my old wheels 17's back on... be careful when buying second hand rims, could end up costing you more than you were intending to spend... :thumbsup:
cheers
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
