Hi guys... I have a fairly stock R33 GTST basicly just has exhaust and boost controller.
I installed a 600x300x76 FMIC over the weekend and notised a fairly big drop in power.
I was running 10psi before FMIC and 10psi after FMIC.
Before FMIC in a strait line in first no mater what if your foot was to the floor and above 4000rpm the back tyres would light up like nothing else. Then if you shifted fast into 2nd the back end would step out and fishy tale hapily. (I have 2x 265s on the rear)
Now I get no wheel spin in 1st and can't get it to loose traction at all when smashing it into 2nd :thumbsup:
Is this just because it lags more with FMIC..? I have my AFM before turbo should I move it closer to the TB?
https://www.sau.com.au/forums/topic/179490-installed-fmic-and-lost-power/
Where are you measuring the boost from?
Is it from the intake manifold, - or the turbo to wastegate line? (where it would read the same but not be!)
Also, silly as it seems, some people have left packing or rags in the FMIC inlet/outlet and had this problem! :thumbsup:
You will notice a drop in response and maybe a little power if you fit an after market cooler to a fairly stock car.Because now the air has to travel further through your newly installed piping which probably snakes through the engine bay.But now that you have installed it you can run more boost providing you will get an ECU in the future.
yeah i wouldnt change to fmic till more mods were done or more boost is used, 10psi is fine for stock cooler, ave some coin for a hiflow then u should see the gain, i had stock cooler on mine till about 2000k's after engine build, car still went good on highway with stock smic but around town was alittle less responsive than with fmic. basically i would think u would need afew more mods to see the real gain the fmic will do to your performance...cheers
I am reading boost from my intake manifold.
I can't run any more than 10psi because I hit boost cut at 10.5psi
with smic I could run 12psi before boost cut but i assume thats because 10psi of colder air is probably the same amount of air compared to 12psi of warmer air.
A stock gtst doesn't need a FMIC, it only causes pressure drop. A FMIC is a supporting mod for when you get a bigger turbo.
I have to disagree with this one...if the car is bone stock then yes...a fmic is not necessary...but regardless...the increased flow and denser air will give a gain...although you will hit boost a tad later due to the increased volume to fill...and you don't need a bigger turbo before you need a fmic...once you start to turn up the boost even on a stocker a fmic would be beneficial...
I am seeing less power over the entire rev range...
Like even after its spooled and I have 10psi showing up on my boost guage it still doesn't seem to accelerate as quick as before.
Doesn't make much sence you would think 10psi would mean 10psi.. meaning same power but should be more because its 10psi of colder air so more oxygen.
I will have to test the cooler for leacks :P it was SOO hard to get the cooler to pipe up as I got a piping kit.. and well it didn't just pipe up I had to modify it a fair bit and it was a real bastard to get the cooler to join up.. any way thats what you get for buying from ebay.
I feel for you mate...my cooler kit definitely didn't line up too...and i had to modify my piping and even my radiator clutch fan so the the piping would fit...it might be a bitch but if you have a boost leak then you have no choice...check the hoses and hose clamps as they are usually the main cause...
What type of intercooler kit did you fit?? Is it a $200 ebay kit or did you spend 600-700 on a hybrid item?
Regardless if the car is bone stock or if its pumping 400hp, an intercooler upgrade WILL make a postive difference, as long it is an upgrade. Some of those ebay kits are really typical china crap and can have more of a pressure drop than the stock cooler and wont flow as they should, but if you got something like a hybrid you should see a gain. I just finished fitting two coolers on the weekend, one on a mates 2JZ supra and the other on a 1JZ soarer and both made noticable gains after taking it for a drive.
I would check simple things like all the fittings are tight and there are no leaks, and although it might sounds silly like mentioned above, double check nothing has clogged the inlet of the cooler (like a rag)...
Now I get no wheel spin in 1st and can't get it to loose traction at all when smashing it into 2nd :P
I think you need better tyres and suspension setup.
In a stock turbo'd car, if your having traction problems its a clear indicator your tyres are worn, or of very poor quality.
As for the rest, get a tune. That will fix it
fitting a bigger intercooler should only mean a fraction more lag while it fills up the larger volume piping, but once it is boosted up it should be flowing as much air, if not more, unless the cooler is poor quality. you are showing this by the fact that rich and retard is kicking in 2psi less. i would check that a joiner hasn't half popped off.
as as nismoid said, if you can fry 265's on a basically stock car, those tyres are extremely crap, and your suspension needs work.
^ exactly what r31nismoid said..
you have 265s and still loosing traction?? on a straight line??
As for the cooler, just check for leaks and what everyone else mentioned above!!
ohh now its time for a tune!!
HAHAHA
yes my tyres arn't that crash hot i have new ones but just need to get them fitted... My suspention is all good, fairly stiff coil overs but still soft enough for a comfy ride.
This car was insane for "stock". It does have a full 3" exhaust including dump etc. and I am running 10psi but I have only had this car for about 3 weeks and you never know what has been done to these cars in Japan before they get here, could have a high flow or something.
Its probably from the 4.39:1 diff gears that make it feel like it has heaps of power and obviously more torque for each gear. 1st does neerly 50km/h when it hits rev limiter >_<
I can just take off wait till 1st gets to 5000rpm drop it into 2nd and the car will step right out and in a strait line.. I LOVE IT!
Also I think I know what the issues is. This morning I notisted the car was running rich and blowing smoke in boost so I assume its leaking so giving the AFM an incorect reading and making it run rich.
This intercooler was off my crazy turbo VS commodore :S so obviously no rags etc where in it.
    • You have found the problem. The wire from the switch to the HB is shorted to earth. Now you have to physically find it and replace it. It won't be the switch, although following the steps above (and yes, where you ask, that is the light switch on the RHS of the binnacle) will rule it out for sure. Or not, if perhaps the switch has melted. But there's no route to earth inside the switch, so I can't see how it would.
    • I did read your post, a few times actually.    Done. Followed this step. [Negative probe should be on the cars chassis. Positive on the wire.]   Did this partially.. now that im reading this over, i only unplugged the LED lights. [Start as said above by unplugging everything (unplug the lights, and switches.] When you are talking about the switch, you're talking about the knob thing on the right side in the drivers seat right? If so, i need to take that apart?  [Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch.] At this point are you referring to the connector by the headlights?  [If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.] Did this. I can confirm that the LED lights aren't the issue [Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.]
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
