Engine Block Reco's
silver gts-t
 Share
looking for some workshops that do good work with boring, honing, crank linishing and general reco work for engine blocks.
If people could list places that they have used and have no problems recommending it would be great.
also prefer places that are inner sydney.
thanks
Edited by silver gts-t
Only two places id use and recommend are Westend performance and duncan & foster.
Sam at westend is responciple for some of the best Drag engines around and many of the top fuelers as well, his done all of my machining for the last 9 years and ive never once had a problem with his work. His all to familiar with the Rb engine as well,
Duncan and foster we use for all out machining at work, they do good work and turn around is very reasonable time wise.
just to give people and idea and to get some feedback
called westend, spoke to sam and he seemed like a nice dude, nice to talk to..
acid clean $75
bore and hone $195
linish crank $49
bearings (king bearings)
$55
$75
forgot to ask about crack testing and balancing a crank >_<
ill call back when i got my pistons..
He is also correct.
Id probably be inclined to fit ARP bolts to your rods if you plan to use them, Close and hone the ones you have and have the little ends checked.
Sam has never let me down and like you say his prices are really good.
 Share
    • Just ordered those bosses, hopefully that does the trick thank you very much everyone for your replies it's really appreciated
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
