Hey,
Just letting every one know that the modified nissans car club is holding another cruise this Thursday night, these are usually really good nights with quite decent turnouts,
please pm me for details
i look forward to seeing a few of you's out there :thumbsup:
https://www.sau.com.au/forums/topic/179514-cruise-this-thursday-the-9th/
Awww crap! I have a Nissan! ..But I kinda can't drive it at the moment. :D
Anyone wanna take me?! I'll keep your seats warm! :P
I'd take you but i'm already taking simon who also has a nissan but can't drive it lol why don't ya get permit?
Was a good night with one (VERY VERY lucky) encounter with the red and blue brigade.
I had fun and PJs was a good windup.
For those who didnt come in, soft! :nyaanyaa:
EDIT:
Just found out at about 12:30 (long after id left) some members of the cruise were assaulted inside PJs in tuggeranong. :thumbsup: This was to do with an external factor (someone on the cruise knew someone there who wouldnt go home with a *%^*head so the %^&$head decided to punch out two of my mates who came along on the cruise as they knew her.)
Not anyones fault who was on the cruise, just the wrong place at the wrong time unfortunately. To anyone who was involved in the scuffle here Daniel extends his greatest apologies about the night and hopes everyones OK.
Edited by low200
For those who didnt come in, soft! :laugh:
EDIT:
Just found out at about 12:30 (long after id left) some members of the cruise were assaulted inside PJs in tuggeranong. :O This was to do with an external factor (someone on the cruise knew someone there who wouldnt go home with a *%^*head so the %^&$head decided to punch out two of my mates who came along on the cruise as they knew her.)
It's all good I got the afternoon off work although fark my head hurts had to actually go to a doctor to make sure nothing was fractured. Shiit happens i guess just hope titans alright he coped i pretty big hit, it just pisses me off we had nothing to do with them and then some gorilla on roids with no dick comes out and just walks up and hits titan then as i'm trying to pull gorilla man off some wank still wearing his safety shirt comes running over and king hits me seriously wtf!!!
How about enough money spent on speeds kills ads and do something about f*ck stains who are so fully hardcore then just have to constantly f*cken start shit lock all the f*ckers up and throw away the key
    • OK, that is a helpful description, because that sounds exactly like a bleeding issue in the clutch....these are hard to bleed manually even when the damping loop has been removed. I'd suggest bleeding again....start by filling the master cylinder up and opening the bleed nipple. Come back and check every now and then that the master cylinder is not empty. Let it gravity bleed for a few hours and see if that improves
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
