Hey forum need your help again I have a fuel pressure regulator on the way and I wanted to know what pressure to set it at to get the most out of the stock injectors. I have a stock turbo as well running 10 psi, what pressure do I set the fuel at to get the most out of the injectors and if I was to turn up the boost to 13 do I then turn down the fuel pressure to compensate for turnin up the boost? Thanks in advance.
https://www.sau.com.au/forums/topic/179547-fuel-pressure-regulator/
Just set it to "factory" fuel pressure, then leave it alone.
So that would be around 44psi and even if I up the boost just leave it at that? There is no need to up the fuel pressure? So what is the advantage of having a fuel pressure regulator I thought you would use it to up the fuel pressure a bit in order to gain horsepower and maximize injector usage.
The FPR takes a signal from the manifold so that it maintains a fixed pressure above the manifold. So if you up the boost, the FPR will add sufficient extra fuel, based on the manifold pressure (= boost).
Adjusting the pressure is a useful alternative to fitting bigger injectors. BUT, you need to re-tune the ECU, because upping the pressure will enrich the mixture, and these engines run rich enough as it is without adding extra fuel.
So if I am keeping the stock injectors just setting the fpr to stock fuel pressure will give a slight increase in horsepower and the stock injectors will be used to their potential?
AN aftermarket FPR wont be of any benefit unless you raise the pressure, but its not necessary unless you plan on making more than 220rwkw. Even then you need management. The only exception in a rising rate reg, but even then you will need management first
Ok here is the story. I really don't plan on making more than 220rwkw in my car, from what I read in the forum thats the safest route to go with my current mods and I dont plan on changing injectors Its virtually stock except fmic, cold air filter with pod, 3.5" turbo back, 255 lph fuel pump, stock turbo boosted up to 10 psi and afc neo. I just want to maximize the stock injectors to get the most flow out of them. So I wanted to now if an aftermarket fpr would benefit any or help me in any way to get the most out of my stock injectors.
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
