Remove indicator assembly, exposes 2 bolts.
2 nuts (?) accessible from engine bay.
I think that's all I had to remove.
Need to jiggle them a bit to get them up and over the front bar.
i tried this when i wnted to make a CAI, and found that even when you remove all the bolts its IMPOSSIBLE! the thing is just firmly in place and won't budge!
I spent a good 3 hours looking for extra bolts but i had something from a website about how to remove the headlight and it showed the bolts to remove. all it will do is wiggle a bit but won't come out!
But hey i wish you luck anyway...
There's 2 in the engine bay.
On the driver's side, there's 1 just below the top of the radiator support panel, and another one about 6" down (behind the P/S lines)
On passenger side, same at top, and 1 down behind the charcoal canister (from memory, its a while since I took the LH one out).
The 2 nuts from the opposite side of the bolts should be welded to the body.
In the worst case, you might also need to remove the front bar.
