Hey guy im fairly new into all of this. Just got myself a 96 r33 gtst series two. It has a blitz exhaust and pod filter fitted. Not sure what to do next....intercooler? BOV? would like to make it a high mount turbo but no sure if thats worth it. Also im on p-plates so i dont want to much attention........ if anyone can help that would be tops. : )
https://www.sau.com.au/forums/topic/179597-what-to-do/
hey mate if ur not lookin for atention dont worry about the BOV i reckon go straight for the frount mount and air intake, dipending on what you like with your car i would go and put an exedy race clutch in, proberly the best thing done to my car.(but im setting up for dori)
the high mount set up is worth it if you are eventually lookin at high power mods like bigger turbo set ups and sh*t.
(or you could just sell it and buy a r32)
hahaha :P
https://www.sau.com.au/forums/topic/179597-what-to-do/#findComment-3271507
Best advice...
Drive it for at least 6 months and get used to the power it already has, in the mean time you can save your pennies for future mods.
Have a look in the 'Forced Induction' section for all your rb25det knowledge, and have a look at what other ppl have modded to get there power gains. :P
https://www.sau.com.au/forums/topic/179597-what-to-do/#findComment-3271524
  SKY RYAN said:
Don't buy a clutch if your stock one isn't stuffed/slipping imo.
Is your exhaust full 3" from the turbo back? If not finish that off - and get a front mount intercooler.
Yup turbo back..and the stock clutch is fine : ) does anyone know a good place for front mounts?
https://www.sau.com.au/forums/topic/179597-what-to-do/#findComment-3271537
  Quote
Cheers mate...That is a dam sexc car btw
Thanks :P
Also, take infamous-t's advice. Drive it around without too many power gains just yet. Learn exactly what you want to do with this car. Plan the whole setup. That way you get used to handling a more powerful rwd car, and you avoid chopping and changing between mods. Get a shopping list and know everything you want before you buy anything :)
https://www.sau.com.au/forums/topic/179597-what-to-do/#findComment-3271586
i reckon go mod by mod unless you are planning on full ground up rebuild which your not, i agree with driving and getting used to it and then adding power but def plan it other wise you will end up buying cheap sh*t off here and never needing to use it
cheers
https://www.sau.com.au/forums/topic/179597-what-to-do/#findComment-3271608
Its best to do a lot of investigation first to figure out what you want. Atm your asking what mod to put in, you say you want a high mount etc. Now these are all valid questions, but you need to know what you want the finished product to be. Obviously things such as a front mount are fairly generic across the range, but there are a lot of little things that can be done to keep your car reliable for its purpose. What that purpose is, you need to figure out.
For instance. People always want to put on a lot of mods and crank up the boost. They forget about important things like brakes, internals of the engine, suspension setup etc etc.
I'd say get the fmic for sure. But before you get a high mount manifold, do some investigation and see what you want out of this car. Then you can plan exaclty what you need, and make sure your car is still reliable and capable of handling the extra power.
Hope that helps. SAU is very useful and full of information. Use the search feature and read a lot. Ask questions of people who know what they are talking about.
https://www.sau.com.au/forums/topic/179597-what-to-do/#findComment-3271624
rofl. Learn how to drive the car. Then mod it. Too many people have totaled their cars within a short time of owning it.
P/s: As R33 GTS said, know what you want to do with the car. Then work your way from there, also understand something called $$ constraints, and possible $$ constraints in the future. 1 very important "mod" ... full comp insurance. :P
https://www.sau.com.au/forums/topic/179597-what-to-do/#findComment-3272159
P/s: As R33 GTS said, know what you want to do with the car. Then work your way from there, also understand something called $$ constraints, and possible $$ constraints in the future. 1 very important "mod" ... full comp insurance. >_<
go for the mods i say!!! skylines are terribly slow in stock form and the only ppl that crash are ppl that cant drive..
https://www.sau.com.au/forums/topic/179597-what-to-do/#findComment-3272500
  Quote
So I assume you were an awesome driver capable of anything as soon as you got your lisence? Don't think so.
nickr33turb is still on his P's, so he's still a young driver. Don't take this the wrong way, I'm not saying cause you're on your P's, you're a bad driver. Just inexperienced. I don't care how good a driving instructor is. Nothing beats experience when it comes to being in control. The more power you have, the finer the line becomes between in control and potentially out of control. I've had my license for a fair few years now, but I still know I've got more to learn. Want to do some advanced driving courses etc.
Get used to the power and rear wheel drive and the feel of boost. Then make upgrades as you go, with a final plan in mind.
https://www.sau.com.au/forums/topic/179597-what-to-do/#findComment-3272512
