  • Replies 40
Hate to do this to you Skyline_Racer but my new ECU just came in. Unfortunately this means I won't have the dollars to get the bar off you this week. If you havent sold it in 2 weeks time I'll get it off you then. Sorry for the hassle.
:chop:
any ideas if the other parts (side skirts, rear pods, rear bumper) are identical to those in a series 2 ? I was looking at having my kit sanded back and repainted, but if they're the same I might aswell grab yours :) do you have any better pictures ?
  • 1 month later...
  • 2 years later...
  • 2 years later...
  • 3 weeks later...
bwahahahahaha!
wtf is wrong with people?!?!?
All of the posts and threads on this board have dates on them. If you can't tell the date, go back to school!
Guest
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
