Well it seems the Crank Angle Sensor has seized up and literally shattered the Cam Shaft Drive in my Rb20det Cefiro, so I left with a dillemma.
Is it worth sourcing out a used/new CAS and cam shaft drive and while im at it get the Timing belt changed over, or should I seriously consider dropping in a 25det.
As far as I know, after fixing this, most of the major problems and servicing will be out of the way for the 100,000k rb20det, and if putting the 25det in is the more viable option, there is no way of telling if I will run into just as many problems with the 25.
What price should I be looking for, with used CAS, cam shaft drive, timing belt and labour.
Atm I am looking for the cheapest long-term fix.
https://www.sau.com.au/forums/topic/179649-best-course-of-action/
as security said go the 30/25. otherwise go a 25. it will be more expensive but will be a lot more responsive than a built 20. the 20's are laggier than the 25 in stock form so if you were to go a bigger turbo on a 20 you would make more power than a 25 but it would be MUCH laggier.
Atm I am not looking for much power, I was chasing about 200kw with the 20, so I am not too fussed about it.
Going 25/30, I'm guessing would cost about 5k, with 25 gearbox etc and labour. What would be required to make it fit in the Cefiro, will it just bolt straight up?
an rb25 turbo on an rb20 with about 14psi and a re-map of stock ecu will put you in the region of 180-190rwkw.
some have got higher.
and RB25 front cut or just engine even is going to be over $2K to begin with.
Rb25/30 is useless unless you have a larger turbo to go with it.
an RB25 turbo will almost be on boost at just over idle.
so a hiflow or second hard GT turbo of some sort adds another $1K at least.
everyone says (and I used to aswell till I searched for cost of parts and added it up), just get a $100 bottom end, bolt a rb25de head from an R32 to it, bolt your bits and you're done.
but then you realise, oh yeh...
gasket kit - $250
new timing belt - $100
new pulley/idler - $100
new water pump (might as well since the belt is off) - $250
new turbo - $1000
modify intercooler piping for the extra 34mm hight in block - $100
modify the exhaust for the extra height - $100
unless you can do ALL these yourself and have all the right tools to torque the head down correctly, you're looking at about $1000 or more for labour.
then you gotta use your Rb20 AFM and ECU.
AFM will max out quick smart.
ECu will need to be re-mapped or replaced with PFC or similar.
might aswell get the Z32 AFM.
there goes another $1800 (rb20 PFC is rare and still around $1500)
then tuning will be about $500 minimum
then you have your car running.
and damn it goes alright..
then, bang.. rattle rattle, crunch, crunch..
oh there goes the glass RB20 gearbox.
let's pull together $1500 for an Rb25 box.
hmm.. clutch could do with a refresh..
not to mention the flywheel.
$400 RB20
$300 rb25 turbo
$500 to get it in the car with new belts etc.
problem solved.
pick up a complete RB25 (in a front cut) and bolt it together... RB20 FTL
rb25 all the way
more torque, more response...and 200rwkw from a 25 (easy to get) will make the car run v.well...great value for money
Saddists :ermm:
Have you bent valves or anything screwy? Cant see how you would have. Sounds to me like you have just damaged the CAS and exhaust cam?
Do a compression test on the engine...if all is well then you can have your car back on the road for less then $800 inc a full service!!!!!
You can grab an RB20 cam for some spare change. Grab a used CAS and get your mechanic to install for you. While the timing belt is off, throw new idler/tensioner and water pump at it, a new Nissan timing belt and you are away.
Listen to GTST, all this talk of "long term" , "cheaper" RB25 RB30 etc etc is in my opinion wrong or very misleading.
RB20s can go punch for punch with the other RBs. Do the sums yourself with your mechanic...but dont listen to anyone who tells you that an R32 with a std RB25 is automatically better then an R32 with an RB20. I woudl very seriously challenge that statement as a general premise :P
dont go and spend 3-5k on an RB25 install only to be demoralised by how much it just cost, or the broken gearbox that may ensue, or the little bit of drama with modding the wiring loom etc and end up selling it. if you have plenty of cash to throw at it...wooohooo, go crazy. But from what i am reading there is no need to do anything other then fix it up and get back and enjoy the car on the road...not lookign at it in the garage and a growing bill :laugh:
Thanks Roy, exactly the reply I was looking for, however I don't think it would be as cheap as 800$. As far as I know, without pulling the engine apart yet, the CAS has had it, and the passenger side CAM shaft drive has shattered inside the engine. Would the fragments have filtered down through the engine? Or would they be contained just in the CAM shaft.
The only reason I bring up a 25 transplant would be if the engine required a total rebuild to get back on the road, of which I would seriously consider spending a little more to get the 25t instead.
Power is the last thing on my mind atm, I just want a reliable fix that will keep the car on the road. Also it is a stock RB20DET Cefiro, so the engine/loom etc is slightly different to the R32, if that makes any difference.
Ring around wreckers and see how much for an RB20DET CAS. I got mine for $130 from memory.
Now the drive on teh cam is literally a little tab that basically mates to the CAS. If it has seized then it for sure will shag the CAS, and perhaps snap the tip off in the end of the cam. It is captive in the end of the cam and wont have been floating around in the head. It will most likely have fallen out when the CAS was removed.
So i would be amazed if you need to pull the engine down and rebuild anything. Grab a timing belt for $90, some idler/tensioner bearings. (Do a search you can get the same thing from bearing companies a lot cheaper then from Nissan), a water pump which is something like $150 from Nissan. So you are up to around $500 in parts.
Float through the classified of this forum, or post in the Wanted to Buy section, all you need is an RB20DET exhaust cam. You will be able to grab one for $50 since you can grab complete head for $150.
So off to the mechanics, where they will remove the radiator to get to the front of the engine. Rip the timing belt off, remove the cam gear and cam cover. Remove the damaged cam, replace with your purchased exhaust cam...put the rocker cover back on, water pump, tensioner/idlers etc and new belt.
You would be up for a good part of a days labour to do it all by the time the inlet peipes etc are all back together. Run this all past your mechanic, but it should only be marginally more expensive then replacement of the timing belt/water pump etc etc as the front of the engine is apart anyway so the exhaust cam is easily changed. Thats a major service so can be seen as a bit of pre-emptive servicing anyway.
So, check with your mechanic, but a snapped CAS drive on the end of the cam should not damage any of the motor. Just means it wont run as the CAS wont be talking to the ECU
More of a concern is the seized CAS! Are you running the timing belt cover. Are you sure the CAS was installed correctly? never heard of one seizing before. Have seen them damaged by being instaled without the timing belt cover and the bushes not used to space the CAS off the cam wheel. But stranger things have happened to RB20s :(
LOL...too many R32s start getting RB25 conversions only for the car to be sold as soon as its doe because the car owes the owner too much money and the gearbox is about to die, etc etc etc
R32s with a basic RB20 can still be damn quick. 100kg lighter and sharper gearing means they can surprise a lot of ppl... :)
I agree with roy in this case, even though i am an rb25 convert. The power you are chasing is easily attainable with good response on an rb20
Any damaged material will be on the front of the engine, rather than in the engine. The only things that could be damaged (other then the cam and cas) are items you will replace anyway as part of the 100k service, like belt, maybe some marks on the tensioners and crank sprocket. nothing major.
So, swap exhaust cam, replace cas, do the 100k service bullshit, probably a good idea to replace the exhaust cam seal just incase it was cut up (check the front main seal while you are there but i'd bet it's ok). Waterpump as you can get to it easily with the belt off.
Roy, if that was a 32 vs 32 battle you might have an arguement...
    • Crazy how good the aero bar looks compared to the stock one
    • Yes, but you will need to rewire all the things that are different. CAS, coils, etc. Yes, but there is no IAT. What? You can use anything you like. It just has to be hooked up so that it will work.     Or are you wanting to just plug and play without having to do any thinking/work?
    • It's been a little over a decade since I bought the S15. As I did on my socials, I'll share some of my favorite pictures from over the years further below. If you haven't realised, pretty much all the pictures in my posts are ones I've taken.  In terms of updates, I don't have pictures, but I acquired a near-perfect pair of fog lights from a friend of mine, so those got swapped in for the pair I already had. As for the JZX110, I just got it back from being fixed. A few weeks back, I was on the highway when I suddenly drove over something with very little time to react. It was probably the size of a soccer ball, but it went under the car and banged into the underside pretty loudly. I pulled over and realized the fluid leaking was fuel, and of course, it was right near my exhaust. This required replacing the fuel tank. If you happen to be in the same predicament, thankfully this car shares a fuel tank with the JZS171, IS200, and IS300, so it wasn't too painful to replace. Enjoy some pictures as mentioned above, including the carnage from the fuel tank and a bonus picture I came across which shows how ridiculously shiny the Bugels are on the 110. So many more pictures I could share of the S15 but this will do for today, enjoy.
    • Welcome.  Was the mistake the car, or joining us? 馃槒
    • Yeap, was me and the daughter getting coffee before heading to the new joint to measure up the fridge space and taking some pics that the solar installer wanted of the switch board
