Just a disclaimer...RB25s in a R32 are good things. I recognise this and i dont believe that the RB20 is a better basis for anything serious or somehting that is to be used in competition where tenths of a second per km hurt you (hill climbs etc etc)
But for somehting you want to spend 5k on and go fast. Well 5k on an RB20 will make for a faster R32 GTSt with a 5k std RB25 transplant. But throw a turbo setup on an RB25 in an R32 and you are laughing :D
But still RB20s are the most unloved Nissan motor. I dare say CA18s have a bigger fanbase, its really a shame as its clearly a good motor in its own right
also..
*Saves "that video" in signature for all to see..
CON STANT LEE!!
LOL...am i that bad at whoring vids of my car :huh: LOL... if only you had of bought my car back in 2002 when i was working in Indonesia. Well i would probably be far wealthier today, and my car would have a tough RB30 if in your hands :)
hmm.. in theory YES..
in reality, it would have just been a nother notch on the CAR belt of TT.
longest I've kept a car is 1.5 years.
I'm now on to my... 15th... since 1996 hahahahaha
cordia turbo
exa turbo
telstar turbo
laser tx3 turbo 4wd
AE82 twin cam corolla hatch
mx6 turbo
liberty RS turbo
AE82 twin cam corolla seca
Silver R32 gtst (this is where your one would have fit)
Galant VR4
S14 200sx
Barina city (hahahahahahahahahahaha <-------- this is what happenes when a $16K S14 gets stolen and you were too tight to have paid comprehensive insurance)
R32 GTS4 sedan
AE93 Twin cam Corolla Seca
Liberty RS turbo
any mathemagicians wna tto calculate what the next car will be?
there's bound to be a pattern.
new water pump (might as well since the belt is off) - $250
last time i checked an rb30e water pump wasn't $250! last time i bought one they were like 35-40 bux.
rb25 for the win. plenty of power with just zorst, fmic and 10psi. Reliable as all f*k.
conversion to my 31 for 5 years had rb25det, cained the kent outta it. purred like a kitten the day i got rid of it. 205rwkw with cooler, zorst and 10psi wid piggy
Edited by Ryanrb25
Firstly, thanks for all the help and suggestions.
I had initially expected the worst, this being, the exhaust cam had shattered inside the head needing a rebuild, however this was no the case. The tip of the CAM, which connects to the CAS has snapped off but the rest had remained in tact.
Thanks to the champs at Boostworx, we replace the Exhaust CAM, CAS, and while we were at it got the bulk of the major service out the way. Tensioner/Idler, waterpump, most belts etc.
Was extremely pleased with the quality of work and service. All work came in under expected cost.
So for the time being the car is purring like only an RB can.
    • Ha ha, all good! I've almost caved in and realised I'm buying one.  I know myself well enough by now that I will start chasing ADHD butterflies half way through building it and not finish it so I'm better off spending the extra money buying one instead of making one just so I can get into straight away.  I would very much enjoy making one as fabrication is probably a strength and definitely a passion but I don't want that to be at the detriment to the car I'm ultimately building it for! There's some pretty good ones around for ~$1100 at the moment so I think I'll just go that way.  At the end I sell it or as mentioned, get another project to make further use of it! Thanks gents.
    • That link was very helpful thank you.
    • That is the option code, not the VIN. Regardless all of that production is considered series 2: https://gtr-registry.com/en-ecr33-vin-table.php
    • Apologies if I sounded like a arse My point was that you will not be able to buy a rotisserie that suits your car, you get the rotisserie frame, and then fabricate parts to mount the rotisserie frame to the body The rotisserie side is easy, but the fabrication of the actual mounts is the tricky part, where to mount so you don't bend/twist the body, plus the geometry involved to get it to turn  If your capable at fabrication, and can work out where the C/L is in relation to the weight is so it actually can turn, you should be sweet I would love to see the progress on this just for the thought processes and fabrication
