Engine, zorst, WG, GB, ECU, Loom etc all came as a package. - Not bad for $1800 !
So, so far my pig project has cost me - $1500 for the car - $500 for wheels and tyres - $1800 for engine etc - $100 for paint - $3900 total.
And for me - the most fun is putting it all together ! :P
  • Replies 183
haha! that is going to be an awsome pig. If you stop putting money into it right now you will bea able to slide it for a year and sell it for $4000 when you are sick of it :whistling:
nice work B-Man
S13 Coilovers, LCAs, Stub Axles and hubs on there way - time for some camber :nyaanyaa:
Lowered double rate rear springs on their way
S15 4 Pot brakes on their way ! -
The good thing about this car is that it is light and newer better parts are cheap as ppl upgrade theirs, they sell of good old parts.
I'll probably end up spending about $5,500 total on it - but I reckon it will go hard, stop hard and corner hard.
Most difficult thing is finding a LSD for cheap - Might just weld it up - but I don't think that would be any good for circuit. Good for Drift, but not circuit perhaps.
Dropped engine at workshop yesterday - Gave it a bit of a clean. Took cam cover off - looks to be in good nick.
Has a VLT turbo on it - with wastegate welded shut at the actuator. However, they didn't completely weld it shut - so it must have been leaking boost - no wonder the dyno graph that the dude showed me looked laggy. 220RWHP - We should be able to fix that sucker and make it go a lot better.
How's the paint job coming along?
And what colour you heading for?
There must be some w/end progress. Post it up!
We've got a retard living nextdoor with a Gazelle.
Spent around $20k all up with no upgrades except a replacement SR20DET and full paint job.
What a waste of money. He could have bought any car he wanted for that $$$
Now paying it off which will take him 30yrs on his pay! Haha.
It does look nice though in black, but 20k !!!! and no air conditioning !!!!
(not meant to be a reflection on B-Man, i just think it's funny)
Steel wheels ??? I plan on turning the boost up ! :P
Yes, the VLT turbo is tiny - but it does have steel wheels
No progress on the Paint - except cam cover and plenum - oh and calipers - this is going to be one technicolour Gazelle. :(:) ha ha
Coilovers arrived
Intercooler Arrived
Some Pics soon !
Very close to putting engine in....
Today I fabricated my own dump pipe. Farken very satisfying making up the custom job.
New gaskets for the top end
Painted cam cover and plenum
Injector kit thu all the injectors.
Pulled the GB off to check the clutch out - all good
Will be great to get out there and do some circuit and drift work again - I miss those days in the Skyline. Eastern Creek, with Maj's father in law in the passenger seat. Benm on the drift day. Then thrashing Paul on the mini karna on the skid pan :wave::):thumbsup:
  • 1 month later...
OK Here's the latest.....
S13 front suspension conversion done - should see the camber now - it's massive
Skyline 4 piston brakes and rotor conversion done on the front !
FJ is going in now - as we type !
pics below !
Yep - Supra still there. I don't know 100% what the story is with that one. But what I do know is that they work bloody fast and well - So I don't think it's lack of expertise or willingness to do the job - I can only speculate.
Also , what I know is that I dropped of my S12 this week and it's a good chance of being all complete by end of next week.
It's going to go hard !
Can't wait !
Yeah the supra project has hit as many walls as steve-o's gtr :P
I would have thought that the engine and accesories would have been put in and back together by now though... maybe they are still waiting on some internals...
  • 2 months later...
    • Do the R32s run high or low impedance injectors?
    • It may not feel like it to your wallet....but sounds like this was one of those "lucky you did it" rebuilds. Hopefully you have better luck this time
    • It's aftermarket. It also reeks of Honda Civic tryhard from 2003. But if you want one....then you want one.
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
