  • Replies 183
Authentic Les Paul Gibson - Just got a new belter of a tube amp for it today ! So much nicer than my crappy old amp
"I got myself a brand new, Tube amplifier
It's large and lovely to behold
La la la la la!"
/POTUSA
Sweeeet!!
Ive got a les paul copy @ home :cool: fakes ftl!
Bah give me an Ibanez neck any day. LP does sound sweet though.
+1
Hell yeah Adam, I ONLY play Ibanez... Ive got 2 RG's at home and I have never played a guitar with a better feeling neck!
(are we getting a little off topic now?) :rofl:
Ibanez necks are too thin & skinny for my hands - I've had 2 and although the action low and fast, not good for me.....
My LP Gibson had the fat 50's style neck - Love it.
I've also got an old Isana (German) - same as the one Elvis used to play (Black Isana is legend - do a google search) - it's 60 years old - lovely guitar to look at - crap to play - has a curved neck on the string side - Not a scratch on it - was my dad's
Anyway - WHAT DO YOU THINK OF MY CAR !
Was the 200rwkw estimate with the old Nissan Turbo from the pics?
If so, what's the new estimate weith Mr.KKK?
Awesome thread this BTW..
And the Les Paul....is it a Studio or Standard...i'd love one of those for my next guitar.
Time for B-Man to start a new thread on axes.... :P
The previous owner of the KKK reckons he ran 320rwkw on an RB20DET
So if I get enough fuel into it - who knows ????
It's a farken great turbo - took it to the shop today - The exhaust housing is smaller than the T3 turbo and the Compressor housing is much bigger - This should equate to faster spool and more power :P:)
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
