Hi,
My fuel pump on my 96 R33 Sh!t itself, what would be some good options for an easy change over, just get a new stock one back in. Or can I put a GTR or something after market in without to much mucking around.
What kind of benefits would i have putting in something after market?
Cheers,
https://www.sau.com.au/forums/topic/179780-new-fuel-pump/
No point going back to standard, upgrade while you can.
I just upgraded from a standard pump to a GTR pump, works minttt.
Go a GTR if you don't want to spend big, it will support whatever you want to do most likely.. or if you really want to go to a new pump go a WALBRO or a BOSCH 040.
Good value for money, and will support big power.
Thanks,
Abu
https://www.sau.com.au/forums/topic/179780-new-fuel-pump/#findComment-3272694
I put a bosch 040 in my 33...worked a treat so far. And preety much silent! (it will be loud if you dont install it properly) You dont have to tweak anything managment wise :) But you will have to slightly mod your bracket and cut a bit off the fuel line that connects to the pump but thats easy to do. There are step by step tutes on this website to guide you through it easy!
A new pump is a better idea than a used 10 year old GTR pump. Worth the extra cash IMO
https://www.sau.com.au/forums/topic/179780-new-fuel-pump/#findComment-3275745
+1 for new pump, dont want it to fail on you again
i put a gtr one in and it was very loud (party because of the bodgy workshop that installed it wrong)
changed it for a walbro 500hp kit and it was much quieter and pretty much a straight swap, all hoses + clamps come with the kit i think the only thuing i had to change was the connectors for the positive and negative.
the 040 bosch is probably equivalent to the walbro one, either way they should both do for approx 250rwkw
https://www.sau.com.au/forums/topic/179780-new-fuel-pump/#findComment-3276696
I just now changed my stock pump to a Walbro..550 hp ..255 lph
Cost me 180 at Autobarn there on special till fathers day.. ;)
https://www.sau.com.au/forums/topic/179780-new-fuel-pump/#findComment-3300440
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
