Hey guys
Got a 1996 model GTS-T M spec for sale
First Ausralian owner
-ABS
- 17 inch Deep dish rims (17x9 rears 17x8 fronts)
- Front and Rear Strut Braces
- Adjustable Coilovers
- Front Mount Intercooler
- 3' Split dump and Front pipe
- 3" cat converter
- 3.5' Cat back exhuast
- Ms Air flow resetter
- Boost Guage
- HKS Turbo Timer
- Aftermarket Clutch
- Aftermarket Mongoose Alarm System with all Sensors (microwave/glassbrake/shock/Tilt)
-Aftermarket Cd and Minidisc player
- Aftermarket speakers
- Full 100,000km service done at 98,000km with 'racing spec' timing belt (silicon)
- Serviced every 5000km using motul oil
- Falkien Tyres in very good condition (255's on rear, 235s on front)
Located in Coffs harbour area, car will be down in newcastle occasionally (pm/email me for details)
price is $15,500 ONO mail me with offers/questions
Contact: Mitch
email: [email protected]
Phone: 0412 591 820
or PM
Pics can be viewed on caresales
http://www.carsales.com.au/used-cars/priva...matchallpartial
I'll post photos on here ASAP (more photos other than carsales ones are avilable on request
Feel free to post comments about car here.
thanks
mitch
Edit:can someone who checks the link to photos let me know that it works (goes straight to the car)
Edit: added new photos to this post
Edited by ZiiN
https://www.sau.com.au/forums/topic/179787-sold/
thanks ill take some more photos tomorrow and upload them on here...
$15,500 ono if SAU is mentioned (just because carsales is shit)
there is a few of the carsales ones attached to here... will get ones in full light tomorrow
very very tidy car
Edited by ZiiN
https://www.sau.com.au/forums/topic/179787-sold/#findComment-3274663
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
