sliver r33 gts-t , selling all parts , both standard and after market bolt ons ,, car made 280rwkw. on 18 psi . has since blown a piston ring . cant be f**ked with it any more , some parts are as follows ...
turbo garrett t66 with braided lines and fittings $1500
sub zero plenum with xf throtle $1500
top mount steam pipe extractors t3 $800
genuine momo stainless 4inch exhust turbo back 1500
700cc bosch injk $500
microtech ltx 12 $1500
long motor $3000
cooler plus pipe work $500
diff offers
rolling shell offers can email pictures or some one can host them for me
melb sales only
also have all standard bolt on;s ,,, will update a.s.a.p.
https://www.sau.com.au/forums/topic/179792-fs-r33-gts-t-all-parts-whole-car/
long motor $3000
diff offers
melb sales only
what kind of Diff do you have avaiable.
Hey mate,
Whats your location and need more info on the long motor...
Who built it
what are the specs
compression ratio (8.5.1?)
What internal work was done?
Whats included?
Cheers
diff is a factory r33 gts-t with 3.9 gears ..
long motor is standard . standard head with adjustable cam gears and mild cams , not sure on specs , standard comp, location northen suburbs.
injectors are a direct fit . made for this car
any questions call phillip on 0418572223 all parts are in perfect working order ,mostly new stuff
car is runing and drivable any test welcome to genuine buyers . please no test piolets .
    • I would not replace the gauges. A well setup tune should never require any of that. I'm of the opinion that if you can't safely hand over a car to your parents to drive it's not fit for purpose and more engineering work should be done. Honestly I'm not a fan of external boost controller boxes either but if you have to you can shove the controller into the glovebox or something once it's set up. Tee it off the OEM MAP sensor. Also you probably want to put a two pin plug on the new solenoid, bolting it to the OEM location works. Just separate the wastegate line and compressor outlet so it will work on a 3 port solenoid, kevboost was walked through how to do this on an RB26, same idea just different locations on an RB25. You may have to remove the restrictor in the OEM hoses if they're still in there.
    • Yep, it's why in Australia we never brought in the 1 child policy like China.  China can't afford to use the shit they make in their own country as it's too much to risk having only one child...  Or maybe that's how they test their shit before they send it to Australia - they use the second kid that families had when they weren't supposed to as the tester?  They weren't supposed to exist in the first place so no loss if they succumb to a work place incident?  🤣
    • It's also the reason neither Duncan or I can own a car rotisserie
    • this is the reason we have more than one child right?
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
