because it was on a downhill use that as an excuse for the car rolling faster than what you thought u were driving?
Few things shit me more than people that can't maintain their speed up/down a hill.
On topic: give it a go but like others, I don't like your chances.
https://www.sau.com.au/forums/topic/179819--/#findComment-3272836
LOL
oh man, same here - they must've send them all out at once!
but i got pinched doing 74 in a 60 zone, same fine and demerits though
i even enquired with some Nyman Gibson lawyer guys online about their claim that almost any multinova rap is beatable, back when i initially saw the suspicious flash.
a few emails back and forth and all i really got from it (without outlaying cash or time i could better spend laying down) was:
"We are in NSW, and the law is no doubt different. However, if the WA people are using the same equipment they use over here, then they are NOT always right! If you are going to defend it, you want to get a copy of the maintenance logs for the particular camera to see if it has been regularly calibrated in accordance with the manufacturer’s guidelines, and see whether it has frequently broken down. Put it this way – they are not going to tell you unless you ask."
...bla bla boring
sure sounded like it was going to be a lot of trouble to me, just cough up the money bro
better than the fine getting any higher due to court costs, late fees or purely annoying the brass
i already miss my clean record :(
https://www.sau.com.au/forums/topic/179819--/#findComment-3274772
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
