because it was on a downhill use that as an excuse for the car rolling faster than what you thought u were driving?
Few things shit me more than people that can't maintain their speed up/down a hill.
On topic: give it a go but like others, I don't like your chances.
https://www.sau.com.au/forums/topic/179819--/#findComment-3272836
LOL
oh man, same here - they must've send them all out at once!
but i got pinched doing 74 in a 60 zone, same fine and demerits though
i even enquired with some Nyman Gibson lawyer guys online about their claim that almost any multinova rap is beatable, back when i initially saw the suspicious flash.
a few emails back and forth and all i really got from it (without outlaying cash or time i could better spend laying down) was:
"We are in NSW, and the law is no doubt different. However, if the WA people are using the same equipment they use over here, then they are NOT always right! If you are going to defend it, you want to get a copy of the maintenance logs for the particular camera to see if it has been regularly calibrated in accordance with the manufacturer’s guidelines, and see whether it has frequently broken down. Put it this way – they are not going to tell you unless you ask."
...bla bla boring
sure sounded like it was going to be a lot of trouble to me, just cough up the money bro
better than the fine getting any higher due to court costs, late fees or purely annoying the brass
i already miss my clean record :(
https://www.sau.com.au/forums/topic/179819--/#findComment-3274772
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
