  • Replies 47
I did it to my car so that channel 4 on the viper remote closes the sunroof and winds the mirrors in. I too like wanky features! Remote start or turning the ignition on winds them out. Carefull not to let the smoke out of the switch though, it can be hard to get back in!
no not the mirror close, just the "mirror close on door lock" function. Coz if i'm in the car driving and I wanna lock my doors, I dun want the mirrors closing on me...
  • 2 months later...
i gave some thought to this, then after talking to a mate of mine we came to the opinion that it would be best have the mirrors set so that when the ignition is turned on they open, and when turned off they shut.
we will try work out how to set this up so that it has a timed signal to reduce the chance of damage to the mirrors. as im not sure if the motors turn themselfs off after hitting full open or full shut. so if anyone knows about that one feel free to tell.
if we manage to work out how to do this one we are willing to either make them for ppl to buy or simply give instructions on how we did it. probally instructions as we are lazy :cool:
few problems we faced...
when you turn ignitoin off, you have to use the power from the battery source (not accessory, as this goes off when you turn the off)
there's a dude in japan who did it and put up a circuit diagram on his website, I saw it, but then forgot to bookmark it.
you gotta rig the power to the switch that controls in out actually, coz it has a relay that stops power to the motor once the mirror has folded (otherwise you'll put a constant power to the motor and cause the motor to die, also it'll drain your batteries)
so it should be...
car turn on -> send 12v to mirror open SPDT switch
car turn off -> send 12v to mirror close SPDT switch
the switch seems to know when to turn off power to the motor so that's all good.
using capacitors and working out by trial and error will give you the size needed for this. so then you have the nice little timed part. the other thing that has to be done is working out how to have a circuit that sends a power pulse when the key is on and when the key is off. i dont know enuff about circuit shit to really say how to do this. in sep ill sit down with me mate and work all this out. shouldnt be tooo complicated.
with those problems you faced. use the power supply on the back of the key. the wire that is always power. either that or use the one that runs to the stereo. and for sending power when the key is off. using a simple cross over relay.
much more thinking to be done once i have someone to chat with that knows more about that stuff.
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
