Car: 1995 R33 Nissan Skyline GTR
Km's: 138,000
Colour: Silver
Mods: 3" HKS super dragger cat-back exhaust
Nismo 320km dash
Sony head unit
Rego: 11 months
Price: $25,300 Not Negotiable
If you look on carsales or autotrader you will see that this is just about the cheapest R33 GTR for sale in Australia. The car is in perfect mechanical condition and any mechanical inspection is welcome. The Nismo 320km dash shows 138,000km but the genuine km's are 140,000. There is one dint in the bonnet, underneath the front spoiler is scraped and there is a small scrape near the left rear guard which has been covered and is barely noticeable unless you really look. The body is 100% straight and when looked at from the side in sunlight there are no ripples or dints. The carpet, front and rear seats as well as dash are immaculate, the only blemishes on the interior is some wear on the steering wheel and the plastic that goes around the power mirror buttons has paint that has flaked off. The engine is in great condition and very clean with no paint flaking off the inlet manifold like many other GTR's which indicates thrashing, the engine also has original stickers from Japan showing the Km's at when the timing belt was changed. The 140,000km on this car are genuine and are very reasonable amount for a car that is 12 years old, don’t believe the 60,000km on other km wound back GTR's. The car comes with 11 months rego and If you want I can get you stock R33 GTR wheels with tyres for $1,400 or you can get the wheels you want to replace the ugly wheels it has at the moment.
$25,300 Not negotiable.
PM me or call 0421715793.
Cheers,
Chris.
Edited by Chris_S15
https://www.sau.com.au/forums/topic/179890-r33-gtr-25300-cheapest-in-aus/
No log books, importer has papers showing each time it was re registered in Japan with the Km's.
So you don't dont really know the km's? You said the nismo dash item had 138K km's. Did you put in the dash? Can't be that cheap if it's still for sale. Man the import market is dead. I still got mine and i need to get rid of it.
I guess you could say I dont 100% know the km's like most other import owners, Ill try and get the papers but like I said any inspection is welcome. The dash was installed by the owner in Japan and has a label on it showing "+2***" so im not sure if this means the original km's are 2***km more or the dash shows 2***km more than the original. Timing belt was changed at 108,000km.
It is that cheap, check the web sites like I said in the original post.
  • 4 weeks later...
Yes they sure are ugly, I'd say they are the reason it hasn't sold already. I didn't think it would be a problem as its going cheap and most owners change wheels anyway but looks like I might have to buy some stock wheels for it, price is going to go up though.
Edited by Chris_S15
Car was stolen from my front yard today between 11am-12am. Was contacted by a "Steve" last night on mobile number 0406335596 who wanted to see the car today and had my address. The car was located in the Wollongong area, if you have any info, get offered cheap GTR parts or have seen the GTR in the pics driving around please PM me.
Edited by Chris_S15
Oh dude this is a nightmare,,,,,, i been chatting with another guy in forum and his 33GTR was stolen last week and he even had a good alarm system on his car and he didn't even hear a thing.. I don't know how these bastards do it.... I think every one should be aware of this problem and open a new topic and discuss about car security... Looks like alarms won't help these days....
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
