Car: 1995 R33 Nissan Skyline GTR
Km's: 138,000
Colour: Silver
Mods: 3" HKS super dragger cat-back exhaust
Nismo 320km dash
Sony head unit
Rego: 11 months
Price: $25,300 Not Negotiable
If you look on carsales or autotrader you will see that this is just about the cheapest R33 GTR for sale in Australia. The car is in perfect mechanical condition and any mechanical inspection is welcome. The Nismo 320km dash shows 138,000km but the genuine km's are 140,000. There is one dint in the bonnet, underneath the front spoiler is scraped and there is a small scrape near the left rear guard which has been covered and is barely noticeable unless you really look. The body is 100% straight and when looked at from the side in sunlight there are no ripples or dints. The carpet, front and rear seats as well as dash are immaculate, the only blemishes on the interior is some wear on the steering wheel and the plastic that goes around the power mirror buttons has paint that has flaked off. The engine is in great condition and very clean with no paint flaking off the inlet manifold like many other GTR's which indicates thrashing, the engine also has original stickers from Japan showing the Km's at when the timing belt was changed. The 140,000km on this car are genuine and are very reasonable amount for a car that is 12 years old, don’t believe the 60,000km on other km wound back GTR's. The car comes with 11 months rego and If you want I can get you stock R33 GTR wheels with tyres for $1,400 or you can get the wheels you want to replace the ugly wheels it has at the moment.
$25,300 Not negotiable.
PM me or call 0421715793.
Cheers,
Chris.
Edited by Chris_S15
https://www.sau.com.au/forums/topic/179890-r33-gtr-25300-cheapest-in-aus/
No log books, importer has papers showing each time it was re registered in Japan with the Km's.
So you don't dont really know the km's? You said the nismo dash item had 138K km's. Did you put in the dash? Can't be that cheap if it's still for sale. Man the import market is dead. I still got mine and i need to get rid of it.
I guess you could say I dont 100% know the km's like most other import owners, Ill try and get the papers but like I said any inspection is welcome. The dash was installed by the owner in Japan and has a label on it showing "+2***" so im not sure if this means the original km's are 2***km more or the dash shows 2***km more than the original. Timing belt was changed at 108,000km.
It is that cheap, check the web sites like I said in the original post.
  • 4 weeks later...
Yes they sure are ugly, I'd say they are the reason it hasn't sold already. I didn't think it would be a problem as its going cheap and most owners change wheels anyway but looks like I might have to buy some stock wheels for it, price is going to go up though.
Edited by Chris_S15
Car was stolen from my front yard today between 11am-12am. Was contacted by a "Steve" last night on mobile number 0406335596 who wanted to see the car today and had my address. The car was located in the Wollongong area, if you have any info, get offered cheap GTR parts or have seen the GTR in the pics driving around please PM me.
Edited by Chris_S15
Oh dude this is a nightmare,,,,,, i been chatting with another guy in forum and his 33GTR was stolen last week and he even had a good alarm system on his car and he didn't even hear a thing.. I don't know how these bastards do it.... I think every one should be aware of this problem and open a new topic and discuss about car security... Looks like alarms won't help these days....
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
