I'd like to say that Adelaide Tyrepower is in the process of fully rectifying the problems I have had and that they have been a blast to deal with and I am looking forward to seeing my car looking the way it deserves on Monday. I may have been too quick to fire in my words in my previous thread but things have all been sorted out now with my car entering Tyrepower once again tomorrow morning. I have learnt that communication is the key to these things and dont let your fustration go straight into many avenues, just stay focused and be reasonable but dont take no crap. Your car does deserve better.
Troy was great with me and very helpful and understanding of the situation I was in and I strongly recommend members to do business with him.
As most of you know my Lenso's did not fit correctly to my car and I was reluctant to do spacers after I rang up regency and just car insurance and madaz input (thanks for looking out madaz, appreciated), so things have changed for the better and I am able to say that Troy has come through for me and helped me pick a rim which would both look great and function well and he is agreed to fix the studs on my car also.
I have decided to go with Koya Inox Imagine 18x8 and 18x9 and I am pretty excited as they look very nice.
I will update with the outcome of the whole process and I should get pics of them on my car on Monday.
I'd like to thank the users that have given me various avenues and support and listened to my problem.
EDIT: And more importantly offered their time, money and help.
Pauly.
http://rapidshare.com/files/49469381/Paulys_got_dish.zip
Pics are up, select FREE not premium to download (For all you rapidshare virgins.)
Non-high res. (800x600)
http://img513.imageshack.us/img513/3636/img5021ck3.jpg -Dish
http://img505.imageshack.us/img505/6665/img5015tb8.jpg -Car
http://img131.imageshack.us/img131/8523/img5020hx6.jpg -My Rusty hub assembly and whatnot
Edited by Pauly33GTS-t
https://www.sau.com.au/forums/topic/179913-my-new-wheels/
  • Replies 73
R33LIN, If you ring up tyrepower they will get you a quote, ask for troy, also, troy is active on NS.com and does publish a few good deals there.
I'm sure if you just pick up a phone tomorow and give them a call he will happily fill you in as he did with me from the get-go.
SUR33L, yeah mate, I know, as soon as I saw those black rims I new they'd match well on my 33 which is silver. It's definitely a nice contrast.
https://www.sau.com.au/forums/topic/179913-my-new-wheels/#findComment-3274323
thanks rbman.
Deluxe, the bitch has been dropped yo... lol.
Just a bit, King lows all round until I pick up a set of more than great coilovers aka Greddy's.
https://www.sau.com.au/forums/topic/179913-my-new-wheels/#findComment-3274533
Yeah might be a good idea I'll ask, but god damn those greddy coilovers look the shit, i know the price is steep but ppl have told me they are second to none.
I'll weigh up the features and performance vs cost. Might just follow ryan up on some.
https://www.sau.com.au/forums/topic/179913-my-new-wheels/#findComment-3274664
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
