hey guys striping a rb25det from a r33.
ecu- $150
loom- $300
turbo- $200
head- $600
block-$400 ( with pistons,conrods,crank)
----$200 for bare block
alternator- $110
starter motor- $110
coil pack cover- $70
rocket covers- $40
cam cover- $40
power steering pump- $50
injectors $110
intake manifold- $50
exhaust manifold- $50
Stock BOV-$65
and all other rb25det engine parts
Im located in Thomastown
email is slighten@hotmail.com
fone number is 0413971969
justin
Edited by slighten
Hey man
Just to let you know RB25DET is an inline 6 engine not V6.
Just thought I would let you know before someone abuse's you :laugh:
Also what condition is that RB25 turbo in!? Much play?
Thanks,
Abu
Edited by abu
Hey man
Thanks,
Abu
there is no play at all she is in perfect condition if u want more information plz call me on 0413971969
is that the engine loom an computer loom ur selling? im looking for just the engine loom.
engine loom n computer loom 300$
i can do the engine loom only for 150 if u like half the price :unsure:
cheers slighten
You have PM :nyaanyaa:
any idea on postage price to sydney regarding intake manifold
Edited by Space Goat
Hey I need the PCV hose (side of inlet cam cover to manifold) if you still have it and is in good nick.
let me know a price posted to 3662
hi there just wondering if you have this piece spare? it goes on the crank between the oil pump and the harmonic balancer i think. there is also a gear in there too if you got that as well?
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 2 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
    • The once piece tail shafts with cv type joints on either end are the ones that end up vibrating and the vibration is caused by the cv joint binding as it turns, I’ve also seen them explode from the binding
    • Take this with a pinch of salt, it's from someone (me) who got annoyed with turbos entirely. I hated aftermarket lines. If I had the option to use hardlines with whatever turbo I had - I would use them, 10/10, 100% of the time. The only reason people go larger, heat resistent, shielded lines etc is because they have to. And yes they don't last forever. Even if you spend big bucks on all the best heat shielding money can buy, with the best heat resistant, fuel resistant, oil resistant, radiation resistant hose, they get stiff and break down and just don't last the way a metal pipe will.
    • Unfortunately I am quite literally halfway across the globe. So all sources for parts like that are far away for me. What do you mean by that exactly?
