Hey Guys couldnt find a thread for this one even though its prob around got my self a z32 and just wanted to know if the myth is true that if u take the mesh cover off do u get more power hopefully i used the right description for wat im talkin about taking off the metaly wirey stuff ahhaa
https://www.sau.com.au/forums/topic/179934-z32-afm/
In theory you will get better air-flow, mine were missing when I got my car, but everyone seems to be freaked about them missing, ... not sure why tho.
Is there someone out there who can shine more light on this matter?
I guess it is to stop debris entering the tracht, but if one is careful, then what diff would it make in reality?.. only better flow..!
https://www.sau.com.au/forums/topic/179934-z32-afm/#findComment-3274929
You wont notice a difference.
Leave it on
https://www.sau.com.au/forums/topic/179934-z32-afm/#findComment-3274939
Hmmm..! someone butchered mine then..!!
I guess there's theory here too... like not letting air enter the area un-distributed... sorta like spreading it out.
When we dyno'd it, we went to replacements, as the MAFS were giving odd readings at times, but we could not pin-point it..!!
Could be this metal grid that wasnt distributing air-flo 'more-evenly'
Anyway, 'tis true, I kept them on. You have to remember that its not about how much air can enter, but what air can be metered accurately.
I go with the "Leave it on" brigade. (plus theres the added benefit of "foreign body ingress" avoidance...!
https://www.sau.com.au/forums/topic/179934-z32-afm/#findComment-3275057
Nissan recommend strongly against removing the mesh, leave it on. Theres a fine coating of Molybdenum, that scrubs the incoming dark matter out of the air. The dark matter can foul valve guides, pit compressor wheels and burn out mufflers prematurely.
I knew a guy, who had a friend, who's battery ran flat with the headlights on in 5hours and 4mins... this was 29mins longer then another guy who had the mesh taken out. Does a positive ionic charge caused by the mesh make the battery last longer? "You be the judge"
Edited by GeeTR
https://www.sau.com.au/forums/topic/179934-z32-afm/#findComment-3275600
Dark matter? sounds like someone has been watching too much star trek...
My personal theory is that it evens the spread of the incoming air, probably more useful at low pressures for distribution accross the sensor, but if you have a look at taps - ones without the mesh covering the outlet and the ones with mesh covering the outlet, run them at different pressures and see how the water behaves. Water coming out taps without mesh will dribble out the side wheras the water from a tap with mesh will spread evenly accross the mesh, then move through... I dont know, thats just me and I could be wrong...
https://www.sau.com.au/forums/topic/179934-z32-afm/#findComment-3275677
the mesh creates some sort of vibration that is required for the afm to read properly. taking this away will aparently LOSE performance...
I searched around and couldn't find anything regarding this vibration. Are you referring to compressor reversion?
Its been toted by many well known workshops and magazines that removing the mesh is one of the first mods one should do, if power was lost or drivability worsened, i think someone would have picked it up. There are many AFM's that don’t use mesh, WRX's are an example that come to mind.
Water coming out taps without mesh will dribble out the side wheras the water from a tap with mesh will spread evenly across the mesh, then move through...
The flow is more even but the mesh in that example is a lot more restrictive, not sure if you can compare pushing a medium 784 times more dense then air with 3bar behind it, to a AFM
Edited by GeeTR
https://www.sau.com.au/forums/topic/179934-z32-afm/#findComment-3275910
Removal of some unwanted material thru interaction/chemical reaction with a catalyst seems like quite a reasonable explanation to me... albeit unproven.
Introducing a source of turbulence and restriction for means of better flow makes less sense as an explanation as to why it is there.
No idea though, hence the question. My 2bob.
https://www.sau.com.au/forums/topic/179934-z32-afm/#findComment-3275929
this gives the AFM a more reliable reading. removing the mesh will give you a rough idle and will also give you bad fuel economy.
Have you seen / felt before and after, or are you assuming? A back to back would be interesting.
I would have thought running a pod filter right on the AFM would replicate the mesh's job. *thinks* wonder if pod setups would suffer these issues people talk of.
https://www.sau.com.au/forums/topic/179934-z32-afm/#findComment-3275950
Well...
Never effected economy on mine, it was superb.... idle... beautiful am afraid, never a complaint from me.
BUT, when it came to dyno time, one had the dreaded disease, so both were changed. There was merely a comment about the fact the mesh was missing, nothing more.
My next point is they would flow more air by simple dynamics at WOT, can't be disputed this part though. (so air+fuel increase)
My car before, did have abnormal power output when compared with a normal set-up, and no one could really say why... maybe..!!
I have to go with M Dave, its to help spread the incoming charge more evenly I think. Basically, the air input is spread more evenly, and thus the charge can be gauged more accurately. BUT at WOT, it has to get in the way, thus restriction!
Dark matter... probably cr@p in a more polite manner..!, but what happens when it eventually gets pulled in, but in bigger amounts as it becomes loosened by its sheer size/mass..??, do the turbos ignore this, 'cos its been through the 'Dark matter' filter?
To remove, or not to remove, that is the question. For 'tis better at low to mid throttle openings, yet can get in the way at WOT.
There, I had to have my say, feel better now.
https://www.sau.com.au/forums/topic/179934-z32-afm/#findComment-3281942
The afm mesh deosnt' cause much restriction at all. If you think about it - its a really thin mesh.
Much more significant gains can be had else where e.g. your rippled air filter - turbo intake pipe. Each of the pipes as it leads onto a silicon join - there's an edge there.
I have listed just two things which would cause more restriction than the simple mesh.
Leave the mesh alone
https://www.sau.com.au/forums/topic/179934-z32-afm/#findComment-3281985
True, the average inlet has soo many restrictions to air -flow.
One way to prove the theory of restriction, if anyone would like to try it is this..
Place said mesh in way of air-flow, and see if it is pulled into the engine..!!, or better for the wallet, blow air at it, and see if you can move it, or do the maths for it. Work out its effective CSA, and then apply as a percentage, and then say it would not obstruct air-flow.
Aaaanyway, we digress.
Simple is easier flow of air, less twists and turns etc makes for better flow, no matter how you view it.
I have seen it removed, and I have to say there was(to my interpretation, at high RPM, better flow... the dyno showed it as such. The reason I think it is there is to aid even distribution of air incoming as a whole, by which the sensor can get a more accurate representation, and to keep
lumpy bits out too.
However, I fail to see that a coating of molybdenum, or anything else will make it disappear.
BTW, there are theorys about having a rough "Wall" to the inlet as being better for flow, rather than as we were lead to believe in the first place..!, look at Thorpeys swim-wear.!
Over..
https://www.sau.com.au/forums/topic/179934-z32-afm/#findComment-3283193
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
