features a fair few skylines....
last night at knockhill.
Car was running sweet as a nut thanks to some weekend work from The Garage in Wishaw.
Clutch was the weak point - but a new one is in the pipeline. Didnt take the car above around 0.8bar so it wasnt stretching its legs at all on the GT2860R's
Some Vids:
http://www.trackscotland.co.uk/vid/SOC/SOC001.wmv
SOC001 : 58Mb - 13mins long. R32 GTR on cut slicks and Wet track.
Lap Times after initial out lap.
78s
73s
69s
73s
72s
73s
73s
68s
as you can see in the vid there was a fair amount of traffic.
http://www.trackscotland.co.uk/vid/SOC/SOC002.wmv
SOC002: 32Mb, 6min long. R32 GTR on cut slicks and drying track. You can really hear the clutch slipping and then the brakes juddering in this one :P
74s
65s
70s
traffic again...
Oh, and sorry about the hand waving from me in the last vid... i must be Italian :ermm:
Didnt take any pics either :laugh:
https://www.sau.com.au/forums/topic/179935-skyline-trackday-vid/
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
