  • Replies 178
was i backing off? sorry didnt think i was, wanted to make sure you had enough room though but dont 4get u got one thing i havent: a turbo!
enough room for what?
once ive gone past, i dont care whats behind me!
and its only a little turbo.
i tried to move things along a litte as its a awesome rd to sit on the speed limit.
however as it turns out 60kph around the corners was fast enough for the r34gt.
no offence intended Cara, but you were going rather gingerly.
which road was this that had stones on it ? :thumbsup:
looked like it was a great day, shouldve taken time off, lol.
cara, didnt get a good look at your car at AS, but it looks great in the pics, me rikey!
yeah Cara your car looks sxc as ... did you end up getting the brakes off of Rob and im not sure why as you allready have a single spot with slotted rotors? :angry::/
im sure they'll live.
you were driving to a level that you felt comfortable.
yeah its never a good thing to drive past what your confidence is
if i can get a mate to go for a drive this weekend i will scout some roads for future cruising
nah didnt get the brakes from rob...........ended up getting Phu's front GTT calipers and 33 GTST rear calipers (only found at the last minute that i need them cause when we put the rear rotors on my stock calipers wouldnt fit on)
ah ok i will message him and see what i can come up with
i dont like the overhang on the 34 with VS bar
ah ok i will message him and see what i can come up with (??????????????????
what overhang? on the wing??
Edited by MissR34
Hey bud, That would be my beast. :thumbsup: What car where you in? Come in to my store and can hook you up with some sweet wheels aswell. :P
Ryan
wasn't there, just saw the pics.
I like your wheels but like mine more, hehe! :angry:
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
