I did the bonnet struts when the car go there - they were dead. Maxima bonnet struts fit and worked fine (sorry the guy didn't know the series they were from so I can't confirm exact model code).
Anyway - my next problem is now the boot struts are dying - does anyone know a local replacement or do I need the bloke to bring his whole collection again?
https://www.sau.com.au/forums/topic/179947-gas-struts/
If you go to any truck or bus spare parts joint they will have them. You only need to know two important things: 1. the pressure rating from the sticker on the side of the strut - in NM newton metres. 2. the travel length of the strut.
https://www.sau.com.au/forums/topic/179947-gas-struts/#findComment-3278809
no pressure rating on the struts unfortunately - that would have been too easy.
Also - they are L and R according to their casings, and they don't use standard ball/spring type mounts. Looks like this is going to be a pain
https://www.sau.com.au/forums/topic/179947-gas-struts/#findComment-3280430
I think you'll find the L and R mean jack shit. I had mine re-gassed the other day and I think I remember the man saying this.
https://www.sau.com.au/forums/topic/179947-gas-struts/#findComment-3281088
Got my bonnet struts replaced from a mobile guy that has at least heard about stageas... i.e he didnt give me the ususal 'you have a nissan what???' when looking for parts.
Can come round to you if need be. Did them for bout $80 on exchange where he gets to keep your ones... they werent any use to me so was happy to hand them over.
Have his details round somewhere, let us know if you need them.
Edited by skye
https://www.sau.com.au/forums/topic/179947-gas-struts/#findComment-3281751
  • 4 weeks later...
prolly the same guy then :) he asked me "nissan what eh?" but then wrote it down afterwards....I'll get him out for the boot as well
Sorry to start up old thread, but my S2 bonnet struts are dying a slow death and will fail shortly i think. So Nissan Maxima bonnet struts fit yeah? The mobile guy should have a pair?
https://www.sau.com.au/forums/topic/179947-gas-struts/#findComment-3325722
Ok my struts died today. In need for a new pair, can someone clarify whether they are the maxima ones that fit? and also has anyone in the sydney area had their's replaced and can recommend somoene? Sorry to be repetitive, just did not quite catch on to what struts were being used. :P
https://www.sau.com.au/forums/topic/179947-gas-struts/#findComment-3328156
true that if you are unshure take your strut with you and show them so the can measure it and they will have a rough idear of the stenth if it's not ritten on it.
go to a truck supplyer or a company that manafactures truck bodies or tradsman trailers and toolboxes.
in newcastle we have ovesco. hope this helps yu out
https://www.sau.com.au/forums/topic/179947-gas-struts/#findComment-3335320
  • 9 months later...
Got my boot struts regassed today, mobile van, $66 total, they were measured at 600 (not sure units, Nm ?) beforehand which wasnt enough to raise the boot, gassed them up to 750, all fine now. top service. http://www.strutregas.com.au/
https://www.sau.com.au/forums/topic/179947-gas-struts/#findComment-3965874
    • No need to replace the cover if it is still intact (not worn through). It would be worth checking the balancer for matching marks on the rear, but I'd assume the balancer was loose at some stage. The cam timing marks look fine, once you put the new belt on you can only be right or a full tooth out
    • Disconnecting rods! must have been an unpleasant surprise...
    • So been ocd with timing mark but checked from few angle and seems both cam are on and crank is matching as well to the slot on sump and crank pully   i noticed crankshaft cover has been robbed as per attached pic. Any ideas why? Could my balancer or harmonic be on its way out? should I replace the cover? https://ibb.co/ZR1JFYRR
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
