Biff Barker Posted August 7, 2007 Share Posted August 7, 2007 Hi there I bought a 2003 MT6 350GT Sedan on Friday and have been having a problem with the keyfob not unlocking the doors. The car locks with the keyfob but will not unlock. To get into the car I have to insert the key into the door lock, unlock the doors manualy and then I have to use the keyfob to unarm the alarm before opening the doors. The alarm is appears to be a factory alarm it has an immobiliser tag which has Nissan on it (see pic) I saw some advise on 35driver.com which outlines instructions on how to reset the keyfob.I followed these and while I was still inside the keyfob locked AND unlocked while but once I opened the door and got out of the car it no longer worked!!! Any advise welcome. Link to comment https://www.sau.com.au/forums/topic/179958-help-keyfob-not-unlocking/ Share on other sites More sharing options...
Pulp Posted August 7, 2007 Share Posted August 7, 2007 Have you taken it appart to check the contacts etc? Link to comment https://www.sau.com.au/forums/topic/179958-help-keyfob-not-unlocking/#findComment-3274832 Share on other sites More sharing options...
Biff Barker Posted August 9, 2007 Author Share Posted August 9, 2007 Have you taken it appart to check the contacts etc? Hi I have checked the contacts and changed the batteries in both keys. Thanks Link to comment https://www.sau.com.au/forums/topic/179958-help-keyfob-not-unlocking/#findComment-3278912 Share on other sites More sharing options...
TechKiwi Posted February 13, 2008 Share Posted February 13, 2008 I have exactly the same problem - I believe it is the door lock motor(s). Have you fixed your problem? Link to comment https://www.sau.com.au/forums/topic/179958-help-keyfob-not-unlocking/#findComment-3642918 Share on other sites More sharing options...
Chris Rogers Posted February 13, 2008 Share Posted February 13, 2008 door lock motor has died. also I would make the suggestion that you pull the OE (dealer fitted ) alarm out before it strands you. if the remote keys die you are stuffed. they are $200USD for the motor and catch assembly. its a major pain to get out. one thing I did note was the G35 used a different system the the V35 in regard to remote entry. the G35 appeared to have a separate remote where the V35 is built into the key. food for thought. Link to comment https://www.sau.com.au/forums/topic/179958-help-keyfob-not-unlocking/#findComment-3643605 Share on other sites More sharing options...
TechKiwi Posted February 13, 2008 Share Posted February 13, 2008 door lock motor has died. also I would make the suggestion that you pull the OE (dealer fitted ) alarm out before it strands you. if the remote keys die you are stuffed. they are $200USD for the motor and catch assembly. its a major pain to get out. one thing I did note was the G35 used a different system the the V35 in regard to remote entry. the G35 appeared to have a separate remote where the V35 is built into the key. food for thought. Chris (or anyone), Do you happen to have correct nissan Part #'s for the CPV35 door lock actuators (motors). I have had great service from 'J's export garage' and think i could get them through them if I knew the right part numbers.... Sad/Funny story.....Right now I have a piece of string tied to the lock inside the car which I pull through the boot (remote boot access still works!) to unlock the door! Before you suggest using the key - The Japanese owner for some reason changed the lock assembly for a high security carbonite? lock - (real skinny key) - which I did,nt get with the import! arghhhhhh... Link to comment https://www.sau.com.au/forums/topic/179958-help-keyfob-not-unlocking/#findComment-3644721 Share on other sites More sharing options...
Chris Rogers Posted February 14, 2008 Share Posted February 14, 2008 giive me a week and I'll have the correct PN for the passneger side. Link to comment https://www.sau.com.au/forums/topic/179958-help-keyfob-not-unlocking/#findComment-3644900 Share on other sites More sharing options...
TechKiwi Posted February 15, 2008 Share Posted February 15, 2008 I've heard from Riverside Infiniti (only took a few days). They want $US350 inc shipping to NZ. I am tempted to go with that but I have a nagging doubt that the Infiniti part may be slightly different than the Skyline unit...can anyone reassure me they are the same? Link to comment https://www.sau.com.au/forums/topic/179958-help-keyfob-not-unlocking/#findComment-3650117 Share on other sites More sharing options...
Chris Rogers Posted February 15, 2008 Share Posted February 15, 2008 for the actuator?? fark! thats not what I was quoted.. Link to comment https://www.sau.com.au/forums/topic/179958-help-keyfob-not-unlocking/#findComment-3650169 Share on other sites More sharing options...
rs73 Posted February 16, 2008 Share Posted February 16, 2008 When you fit immob & alarm on mine, did you find any factory OE alarm fitted? Link to comment https://www.sau.com.au/forums/topic/179958-help-keyfob-not-unlocking/#findComment-3650973 Share on other sites More sharing options...
Chris Rogers Posted February 16, 2008 Share Posted February 16, 2008 yep and I removed all of it. the whole lot was in with several loose scotchlocks so the whole lot came out. Link to comment https://www.sau.com.au/forums/topic/179958-help-keyfob-not-unlocking/#findComment-3651029 Share on other sites More sharing options...
TechKiwi Posted February 16, 2008 Share Posted February 16, 2008 for the actuator?? fark! thats not what I was quoted.. Well... I read the email again: it was actually US$340 and was for both sides - how does that compare? Whats your feeling ...do you think the Infiniti parts would be the same? Link to comment https://www.sau.com.au/forums/topic/179958-help-keyfob-not-unlocking/#findComment-3651325 Share on other sites More sharing options...
Chris Rogers Posted February 16, 2008 Share Posted February 16, 2008 thats better. about what I paid for one side($195USD). same parts differnet badge. both are nissan. I'm seeing these cars with the G35 badge on them occasionally and more of them with the full swap lately, Link to comment https://www.sau.com.au/forums/topic/179958-help-keyfob-not-unlocking/#findComment-3651367 Share on other sites More sharing options...
