hi i hav a skyline r33 gtst auto, my mods are turboback exhaust, greddy fmic, blitz podfilter, greddy emanage, and dual stage boost controller, i recently put the e-manage in n got it tuned with new spark plugs. it dynoed at 194 kilwatts at 14psi, but as u can c in da readout ders a massive power loss, and den it shoots back up, my mechanic said ur cam timing is mostly likely out, i just wanted to know that when the cam timing is fixed if that is the problem, if i will gain more kilawatts, and secondly with the mods i have, is the kilwatts matching the mods i have?
https://www.sau.com.au/forums/topic/179979-plz-look-at-my-dyno-readout/
Ok.
1. Back off the boost to 12psi at the most. 14psi WILL shorten the life of the turbo. Its been proven time and time again.
2. Its either timing is out, or the tune is shit. There are only two choices there... and its pretty dreadful at that.
Once its fixed, you back the boost off to an an acceptable level, you'll make around 180rwkw being the auto will suck a tad of the power
why would the cam timing be out? have you had a new timing belt put on? i doubt its cam timing
That dyno sheet shows a massive loss in power, whats it like to drive on the street before and after the tune? does it feel like its hesitating? Your max hp is pretty much spot on for the mods, so i wouldnt really expect you to gain much more power, but that mid range definately needs to be fixed up, and you will notice a big difference on the street once that is done. Did you have a dyno reading before the tune? I cant believe someone would send that out the door and say its "tuned"
looks like R&R to me aswell.
it pulls a heap of timing out as soon as you hit 13psi and then when it tapers off again the ecu starts to behave again. I hope you did not get charged for that "tune" :P
could also be coils breaking down. ucd15r33's dyno sheet looked like that and he has a remapped ecu and a emanage. his car was missfiring and there was a coresponding drop in power, then it came good and boosted up again. i will post the graph of it soon.
hang on a second....
This is a auto yeah ?? then wait.. that graph may not be what it looks like... Think about it.. it starts at 70k's an hour and goes all the way up to 170.
Now correct me if i am wrong but a auto CANNOT do that in second gear. my car was auto when i got it. So i know.
I think what has happened is that the way the guy did the dyno run. that long flat spot would be where he backed it off to change gears and then when it settled in the gear he floored it again.
If you look in the middle of the line you can see it was going up a little then back down again.. that was done with the accelerator.
If the car did have a curve like that it would feel sooo sluggish till about 5000rpm and then come on very hard.
Its just the way he did the power run i wreckon.. I dont think its because of the tune. it could be but looking at that there must have been a gear change somewhere and this tuner may have been just looking to get a max power print out for his customer because max power is where its at these days!! lol
Seems soo easy for people to out and blame the tuner all the time.. tuner this tuner that.. rah rah rah.. maybe it was his fault for letting a crappy print out like that from his shop he could have done a ramp from 110ks an hour to 180 and get a better curve.. BUT i cant say that for sure there could be many reasons for why he did it this way.
Edited by Guilt-Toy
can you tell me what speed does your car change from second to third?? from memory i think it was at least around 120 - 130ks an hour right where the big power increase comes in and goes straight up.
I think i may be right on this one.. the only thing that confuses me a bit is the boost curve... may be boost controller related or maybe he did not back off the accelerator too much to bring it up to speed for the final power figure.
*shrug* i am open to any comments if anything thinks i am wrong. i have had a auto r31 skyline rb30e on the dyno and when it changed from first to second it felt like the dyno was going to top over the car nearly jumped off it (i was not driving the owner was i was just using the controlls) and the way i had to get the power run properly was to get him to drive it to 100ks an hour and then start the run from there in 3rd gear. Worked well.. 105rwkw
full power in third gear was using 10 - 12 psi as you can see where the power flats out on the power curve the boost went down to that level.
I think this tune may be good and if it is this car should feel pretty quick on the street.
Ok.
A auto with that much power on a dyno in second gear at full noise will come very close to jumping off the dyno ESPECIALLY when it changes to third gear.
I think it was the way the dyno run was done.
The only way we are going to know for sure is to get the owner of the car to tell us how the car drives on the street. does it pull hard from 2500rpm onwards all the way or does it feel dead and no ones home untill 5500rpm.
but at full noise in 2nd gear it should be making more than 120kw (closer to 195kw), and the boost should drop off as there wouldn't be as much load.
i still reakon it is a spark issue.
the run was done in 3rd gear.
theres no spikes where it changed gear so that tells me that the tuner doesnt know about the magic brown plug, and hence he has slowly built the speed up past the point of no return for second gear and then he has planted it.
behind the driver side head light there is a group of electrical conectors.
find the brown one and unplug it.
this will lock the car in drive, so the tuner can then load up the car throughout the whole rev range without it kicking back to second and trying to kill everyone.
aprt from that power is ok but not great.
i had 187 from stock computer, stock auto.
sell the emanage and put a power fc on it...
thats exactly it.
or do what dangerman said and unplug the brown plug and get it on the dyno again.
yeah i didnt think it was the tuners fault. i heard good things about this tuner in particular so if anyone reads this thread dont think he is a bad tuner. he is a good tuner he just does not know about the brown plug in the r33's to lock it in drive. (neither did i to be honest)
I am willing to bet the tune is good and the car would be fun to drive.
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
