what mph are you crossing the line at?
and was it 121hp or kw, cause i don't think you could do it with 123hp, even if you had drag slicks. if it was 121kw then i could believe it since i managed a 14.8 out of a magna with a 60ft time 0.187 slower than you. if i got a 2.0 60ft i'd be somewhere round the 14.5 mark.
i also notice that the dyno run you have posted says in the description that you say the car has a blocked cat, so if it does, what does it run without the blocked cat?
  • Replies 56
once again to clear things up, the car ran 123rwhp on the blocked cat, the 1/4 mile run was done with a new cat
No slicks were used, i explained what the car has done to it, nothing more nothing less.
If anyone lives in WA and wants to verify that it is what i say it is, then they are more than welcome to inspect the car.
Im not rogercordia, i dont have a need to make up bullshit
Im not rogercordia
rofl...
your brother may have set a new bench mark for NA times. i'll take it down the strip when i get a spare chance.
i make 115kw, which is roughly 150HP - we'll see how it compares.
Have you got any mods? If so, what mods.
My RB25DE with only cat-back exhaust (probably makes no diff anyway) make 115kw aswell. No other mods, I am sure of that :whistling:
didn't dial any timing in. it's still whatever it is from the factory or previous owner.
the safc was to clean up the afr a bit not for any sort of power.
most of my mods are based around suspension parts and setup, not power.
although i might have to put some in to try this drag racing thing you guys call racing.
hahahaha, i'm kinda the opposite, mostly been racing my cars down the strip but with the new gt-four im keen to throw it around a track, even if it does mean i'm just going around in circles....
Vote1 for Shaved head/thinner head gasket.
Increases CR a bit.
Most likely a few degrees extra dialled in on the CAS.
Check what timing it runs at idle, unsure on the GTS, but on the GTS-t it should be 15degrees.
Increases CR a bit.
It definately has timing smashed into it, i said that on the first page. From memory the cas is pretty much maxed out so its probably running around 25 degrees of timing at idle lol, which kinda throws the shaved head out the door cause with the extra CR and all that timing its would be pinging its nuts off all day long which isnt the case
Im getting my n/a tuned it already has a catback and coldair/pod. It is getting a piggyback system,cams and a lightened flywheel. When its all done ill scan the drag slip onto the computer :O
good stuff, post up what power you get after the tune aswell :D
anyone else has got a time to post up please do, i wanted to get some general comparision going to set a general bench mark for n/a owners but the thread kinda got sidetracked lol
there is the oppportunity if me might being able to do a 1/4 mle in november but i dont know if i want to cause my poor engine is tired and im ummmm'ing and rrr'ing about whether to do it or not..................
just do it... lol
    • EDIT: Just a little info what my tranny is "doing" :   For the long time the trans do this "bad" sound:https://www.youtube.com/watch?v=qs_iTXgDt40 It is literally the same sound and same symptoms(when i push the clutch it quites down) So is it really the shaft bearing?   Also:  i found this on forums: The RB20 and SR20 boxes are nearly indentical inside (rb20 has longer mainshaft)and suffer badly from bearing and selector failures when driven hard   The bearing is true and selector failure kinda too...it is "harder" to get into gears specialy when i drive a little bit hard...
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
