Well, if you've done your homework and put the thing through a wind tunnel etc, then it'll do something. TBH, I would be surprised if the generic ones that I'm looking at actually do anything. I mean, maybe around turn 1 at EC I'd notice a tiny difference. But other than that I doubt the ones I'm looking at would do little if anything at all.
lol wind tunnel. yeah Geoff shame on ur for no wind tunnel testing...
As I said.... The ones I'm looking at most probably don't do anything. OMG, I should put a GT wing on my car so I can increase downforce :(
Did you know if you install an R33 GTR copy front bar you increase front traction by 60%? :rofl: (I'm being sarcastic btw)
Basically what I was saying in that post of mine that you quoted is, if you don't have proof to back up the things you're saying, then I'm going to keep on believing that these rear diffusers that I'm looking at do jack shit.
And hey, khunjeng, I never said Geoff's diffuser didn't do anything, I just assumed that because he thought he'd drop his "qualifications" in his post that he would've done some measurable testing. What I said was the diffusers I'm looking at don't do anything. So go take your sarcasm somewhere else.
This is, afterall, the "cosmetic and styling mods" section.
i like the seperated difuser look better like the top secret one.
thanks!
i was unable to ship the one-piece diffusers from japan as it was just to big for EMS, so i sent with the seperated design and unlucky it was just under the max size for EMS. my car is in the paint shop this week so i may get them to throw it on, as ive had it for along time and its just sitting in my room
As I said.... The ones I'm looking at most probably don't do anything. OMG, I should put a GT wing on my car so I can increase downforce :D
Did you know if you install an R33 GTR copy front bar you increase front traction by 60%? ;) (I'm being sarcastic btw)
maybe you should take ur own advce?
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
