On another note I heard the reason they don't use helmets on the skidpan at deca is that all the melbourne-ites complained that putting on a helmet ruined their metro-fag mowhawks for the rest of their day and spoiled their chances of picking up in Benala. Any truth to that?
Thats been a long held suspicion of mine. :( Also the fact they cant readily check their hair out in the rear view before pulling up into the garage, they live in constant fear of being photographed in bad light, or from the wrong angle or with helmet hair. :mellow:
  • Replies 109
I can dish it...
ummmm
ummmmm
ummmmm
I'm taking my bat and ball and going home :)
Ok. Rule No 1. Dont take any sh1t from Victorians, or swine like me. Im lower then a Victorian as i got lost one week and ended up here, and dont have the common sense to get out. So, dont pack up your bat and ball. Stand and fight. The bigger the lie the more people want to believe it.
Like, Victorians spend more on hair care then they do on birth control. This vice explains things like
Ahhhh, yes Mowhawks you say, metro-fag huh.....Oh you mean like this?
It's OOOOOOOOOOONNNN Beer Barron, On like Donky Kong!
with a melbourne style hair cut like that I reckon outside of that photo the only gun he's been holding is his boyfriends mutton gun... he looks about as hard core as a bowl of jelly.
Yeah, never mind though, I did have a Heckler & Koch USC 45K in my hand....and YES thats ALL I had in my hand before you ask.
Maybe this is more your kit, my holiday fridge Team Wang style! :banana:
OMG Jagerbombs!!!! ;)
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
