Hi Guys
Just wonder if anyone can tell me the location of the sensor for error #23 - Steering Angle Sensor Neutral Not Present.
I have had my car to a workshop as the rear end tends to sway left to right, they have told me that this is the error coming up on their scanning machine but are unable to find where the sensor is located. If anyone could help that would be great.
thanks
Jaron
yeah dude, the sensor is behind the steering wheel, think its an 18 or 22mm nut?
It's round 8-10cm in diameter and 2-3cm thick
It's basically a round thing which moves left/right, it's black with a brown plug on it
If it's not there, sounds like someone might have to taken it out
If that's the case, get a lockbar kit and lock the rear steering up
If it is there, it's possibly not plugged in or faulty, check the plug is in, if it is, unplug and replug it
If you want hicas, just get another sensor, there should be a few available after people upgrade to non-hicas boss kits and remove their hicas
The above info is for an R32, which I'm assuming you have? it will be similar for an R33, but I'm not sure about an R34
Hey mate
I have r33, i will check behind the steering wheel tonight and see if the cable is plugged in. I would say it is plugged in but the sensor is shagged.
Any idea on how much a new sensor would be? failing that i might get a lock bar!
thanks again
Sorry to hijack a thread..
So HICAS does not go into a default mode if it loses signal from a sensor? i.e. if it loses steering angle or road speed signals, I would have thought it would lock at it's zero'd setting not just let the back wheels flop about..
Basically I was wondering whether to put my steering wheel/nonhicas boss kit on now or wait till I put my lockbar in..
no i don't think it locks, you'll find that if you pull the ECu or sensor, it'll start crabbing :S
Jack it up, remove the ecu and then try pushign the wheels, you'll see they will move slightly :S
What a stupid system, you would think that the engineers would have thought that if in case the ecu lost a sensor signal it would default back to "no steering added" or some such default.
Oh well, no steering wheel till the lockbar goes in :)
even with the lockbar I would strongly advise using a compatible hicas boss kit with your steering wheel. the hicas computer also control power steering function and you don't want to mess it up. :)
    • All the schemas I can see, indicate your typical setup of ATF 'cooler' (read: heat exchanger) in the bottom radiator tank..ie; https://nissan.epc-data.com/stagea/wgnc34/5413-rb25det/engine/214/ ...but I can prattle on a bit here. These trannies have a thermistor in the sump ~ the TCU reads this and 1. bumps the line pressure up when the ATF is 'cold' and 2. prevents the TC lockup clutch from operating, until the ATF comes up to minimum operating temp (keeps the ATF 'churning' through the TC so it heats up quicker) -- trigger point is around 55C. In these conditions, the engine coolant temperature rises faster than the ATF temperature, and also helps heat the ATF up, which is why it's best to think of the in radiator tank setup as a heat exchanger ; the heat can flow in both directions... ...with these trannies, the 'hot' ATF comes out the front banjo bolt, flows through the cooler/heat exchanger, and returns to the box  via the rear banjo bolt. This gets a mention, due to the wildly different opinions wrt running auto trans fluid coolers ~ do you bypass the in radiator tank altogether, or put the cooler inline with the in radiator tank system...and then, do you put the additional cooler before of after the in radiator tank system?... ....fact is the nominal engine operating temp (roughly 75C), happens to be the ideal temperature for the ATF used in these trannies as well (no surprises there), so for the in radiator tank system to actually 'cool' the ATF, the ATF temp has to be hotter than that...lets say 100C -- you've got 25C of 'excess' heat, (slowly) pumping into the 75C coolant. This part of the equation changes drastically, when you've got 100C ATF flowing through an air cooled radiator ; you can move a lot more excess heat, faster ~ it is possible to cool the ATF 'too much' as it were...(climate matters a lot)... ...in an 'ideal' setup, what you're really trying to control here, is flash heating of the ATF, primarily produced by the TC interface. In a perfect world, wrt auto trans oil cooling, you want a dedicated trans cooler with builtin thermostatic valving - they exist. These should be run inline and before the in radiator tank system ~ when 'cold' the valving bypasses the fin stack, allowing the ATF to flow direct to the in radiator tank heat exchanger, so it works 'as intended' with helping heat the ATF up. When 'hot' (iirc it was 50C threshold), the valving shuts forcing the ATF through the cooler fin stack, and onto the in radiator tank heat exchanger...and you sort of think of it as a 'thermal conditioner' of sorts...ie; if you did cool your ATF down to 65C, the coolant will add a little heat, otherwise it works as intended... ...the 'hot' ATF coming from the front bango bolt, is instantiated from the TC when in use, so all/any flash heated oil, flows to the fluid-to-air cooler first, and because of the greater heat differential, you can get rid of this heat fast. Just how big (BTU/h) this cooler needs to be to effectively dissipate this TC flash heat, is the charm...too many variables to discuss here, but I just wanted to point out the nitty-gritty of automatic trans fluid coolers ~ they're a different beastie to what most ppl think of when considering an 'oil cooler'... /3.5cents
    • Been a busy but productive day. Axle and hubs acquired. All fitted up after a bit of modifying. Need to sort out wider mudguards and running light reflector covers but other than that the trailer is gooood to go !!
    • Selling a SMIC for a Nissan Stagea C34 Series 2 and the pipe from the intercooler to inlet. (I believe it is the same R34 GTT, please correct me if I'm wrong) Price: $50? I dont have a photo of the big black pipe that goes from SMIC outlet to throttle body.
    • So the original radiator is leaking now. Looking at getting a fully aluminium one next. Am I correct in saying that the Series 2 Auto Stageas have a separate trans cooler from factory (located in between the rad and intercooler in my previous post/message).   Currently looking at Fenix $460, Blitz $700, GReddy $800, and KoyoRad $740. What are everyones thought on Fenix ( ive read a few comments saying theyre cheap Chinese rebrands etc and how their build quality is... well.. chinese...)  compared to the others? Worth the extra couple hundies?
