This morning I jumped in my Skyline to go to work and went to get out the shut a gate and the bleedin' driver's side door wouldn't open!
When I start the engine the doors automatically lock themselves and to get out you either have to switch the engine off or flip the switch to the unlock the doors manually. When the switch is flipped on the drivers side it automatically unlocks the passenger side door also.
So I'm trapped inside my own car and was forced to crawl out the passenger side door, not very graceful. But no matter what I do I cannot get the driver's side to unlock, either manually from inside the car, from the outside with the key fob or with the key! I've also noticed that as of late the power window on the driver side doesn't work consistently when I go to wind it up, winds down fine but to get it up some times I will have to flip the switch about 5 or 6 times to get it to work, I don't know if this has anything to do with it, it just seems a bit suspicious that the electrical stuff on the drivers side doesn't seem to be working properly as of late.
When I press the keyfob the lock switch does flip back as if it is actually unlocked but the door just will not open.
hmmm.... I have the opposite problem: I have trouble getting the drivers door to lock. Good luck: I will keep an eye on this thread.... I suspect my problem has a similar cause
sounds to me like one of your linkage rods have popped off or broken.....i have a similar prob but mine is an electrical fault, in my r34 the central locking isn't working on the passenger side.
It turns out the latch on the door is jammed and it's riveted together so I am currently in the process of sourcing a new one. The auto-electrician somehow managed to get the door open and removed the latch which can't be dismantled without essentially destroying it so, bit of bad news there - the fun part is going to be finding a replacement!
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
