Here some information about the nismo clutch (got from the nismo catalogue)
SUPER COPPERMIX
Allowable torque of 54 kgfm for dynamic friction (station friction: 81kgfm) Handles an estimated allowable power of 420PS
This is a single clutch system that takes "the ease of use"and "high power handling"forte of COPPERMIX to the next level.. This series also includes a lineup of standard specification products that can handle 380P
*NISMO standard measurements taken by combining high-power specification with the SR20DET engine.
Lightweight flywheel - Equipped with a lightweight flywheel manufactured form special chromoly, the ideal weight has been provided to ensure torque
Aluminum Cover - A cover made from a special aluminum with excellent heat-radiating powers is used
Center Plate with strap Function - To deal with unlikely occurrence of misshift, the center plate features a strap function
SUPER COPPERMIX TWIN
Allowable torque of 84kgfm for dynamic friction (station friction: 143 kgfm) Handles an estimated allowable power of 670PS
The multi-plate clutch takes "the ease of use" and "high power handling"forte of COPPERMIX to the next level
*The numerical values are NISMO standard measurement values measured using a push-type clutch combined with an RB26DETT engine. Evaluation were made based on street and circuit conditions. No quarter-mile evaluation was conducted
Uses an aluminum cover and lightweight flywheel as a set - A special aluminum cover weigh excellent heat radiation is employed. Also, this is combined as a set with a special lightweight chrome-molybdenum flywheel to achieve the ideal weight setting for the attained torque.
Hope it helps :)
Cheers Michael
thanks Michael but does this apply to the clutch kit also ? and 380P is that hp ? and whats 420PS mean. sorry i've got no idea on clutches. thanks
and what would be the difference between a copper mix and a non asbestos clutch ?
Edited by nsm034
thats good to know thanks heaps for your help :) micheal . heres a link to the one i'm looking at
http://www.perfectrun.com.au/performance%2...tsclutchkit.htm
i'd say copper mix is better because it's dearer. :mellow: would that be a fair asumption ? ha
Hey mate,
Im looking at the same clutch kit, they sell it without the flywheel for about $500 also. Just want to know, what are ppls thoughts on the advantages on a flywheel? Do you guys believe there are any power gains to be made on a dyno? From what I've read there is no dyno difference however on the street, it is like having 101lbs less weight on the street???
Edited by MR R34
I got a nismo twin plate + light flywheel and I hate it. Way too on off for city driving. I'm going to get it replaced by a single - already have nismo slave so should be heaps better for traffic.
Is this a Super Coppermix, or a G-Max or earlier clutch? Just trying to figure out which one you have coz the Super Coppermix is supossed to be the ducks nuts
Let me know if you wanna sell it
It's a Nismo Gmax Item - I'll have to find the version number. It's not too bad while your moving just annoying to drive to and from work and stopping at lights etc. Which is basically 90% of my driving - I'm rebuilding engine at the moment so I'm keen to replace it with a decent single.
  • 2 months later...
