OK looks like this is back up for sale, In our new house now and if i want the things i want its gotta go. New car is on the way aswell so something has to give. Have reduced the price $5000. Unfortunatley in 6-12months i'll have the money for something like this again but not now... I hadnt moved the car since september and in that time the AFM has died so i will get a new one soon and the windscreen is cracked.
Im selling my recently completed R34 Drift car. Unfortunatley due to a change in circumstances i wont be able to use it to its full potential.
The car is a RACE/RALLY rego ONLY it cannot be registered EVER. So please dont ask about compliancing rego etc etc...
The details are:
1999 R34 Skyline Sedan (had 73k's)
Factory NEO turbo Auto
Engine:
1994 180sx SR20DET with 60k's
Trust TD06H-20G turbo
Tial 38mm external gate
High Mount manifold
Nismo 550cc injector's
FMIC
Retuned ECU
Z32 AFM
Full 3inch exhaust
K+N pod
Oil cooler and relocator
Catch can
Custom Engine loom by PLMS devlepments
Driveline:
S13 5 speed
Extreme Clutch
Custom 2 peice tail shaft
Shimmed Stock Diff
Suspension:
G4 coilovers with custom spring rates to suit SR20 conversion
Front Nismo Upper control arms
Rear camber arms
Hicas breaker
URAS extra lock spacer's
Front 20mm spacer's
Wheels:
URAS 17x9 + 30 with falken tyres ~ 50%
URAS 17x9.5 + 15 with average tyre's
Interior:
Fixed back seats on Bride super low rails
Racing logic hydraulic handbrake
Deep dish steering wheel
Custom dash setup with Apexi RSM as speedo/tacho
autometer fuel gauge
custom warning lights
4 X defi style gauges
relocated battery
2 X harnesses
completely gutted dash/ interior of all trim and sound deadning
Exterior:
Full nismo option skirts
maseratti orange paint
Thats all i can think of atm
i have weighed the car with the SR conversion it came in at 1240kg 240kg lighter then stock!!
have also had it dynoed at 296rwhp @ 12psi
Since completion i have taken the car to one wet track day and only done around 300 road km's. Everything was baught new for the car. I wanted to build something reliable from the start. The only thing the car really needs is a 2way diff and it is finsihed. Took the car to a drift comp sept, dry day at last. Went damn hard came 4th which i was happy with seen it was the first time i had drifted on a dry track in 2 years!! Easliy fried the 17x9.5's with 235/45's so much grip with them to was awesome kept up with a 430rwhp ceffie!
Im looking at around $25,500 $21000 $20,000ono
if you have any questions please pm me.
Im located in Bunbury WA (2hours south of perth)
I will post photo's later for now please see the link at the bottom of the page.
please keep any negative comments to yourself.
Edited by msports180
i will throw in 4xr33 stock rims with tyres so then you have everything you need straight away to go drifting.
You can fit 4 rims and tyres where the back seat used to be and another 4 in the boot :P
$25,500
this thing is ready to go, anyone looking into drifting this is it. So balanced, very smooth on transitions. Beautifull to drift. Only needs a 2way and thats it. Then nothing else needs to be spent on it.
I will do this cheaper with stock turbo/ecu/inj's
or will swap for a jzx100 chaser manual/s15
or c33 laurel plus cash my way
need it gone
Finnally got to use this thing in the dry on sunday. I gotta say its so much fun. The longer wheel base is such an advantage you can just hold it flat where alot of the s13's r lifting off. Awesome car, came 4th in the local comp. Someone must want a car thats ready to go. Jump in and start winning and be different!! Car never missed a beat all day, no problems at all. So ive used it twice now.
I get the keys to my house in 3-4weeks so i need this gone.
yeh im in WA. Nah its not the holden colour, its a maserati orange apparently. If u put it next to the holden colour its slightly more orangey
need this gone.
may swap for a 4x2/4x4 dual cab ute worth 10k ish and the rest in cash.
  • 1 month later...
lol looks weird a SR20 in the house of a RB.. lol haha
Crazy car man.. i'm lookin at buyin or buildin a track car but this is way out of my budget... good luck with the sale..
GUYS THIS CAR IS READY TO GO.. U WANAN DORRIE, PERFECT WAY TO START OFF!!!!
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
