  • Replies 287
They look awesome printed on vinyl, but thats pretty pricy here in Australia - If anyone is going to Thailand soon, its only about $20 for A1 and A2 sizes.
If you're printing and its one of mine, let me know which one and I will give you a higher res/full size one to send to printers
I'll see what I can do about Prints for everybody, I have a few friends in the trade that could help me out.
If you can wait for the raw image from the camera, they're 3888x2592 pixels and most are about 4mb each. You'll get a better quality print.
I'll get back to every body asap.
Cheers
J
Digging the two-tone sedan :pwned:
That belongs to Me, Frink, Bluprint's mate Jeremy, its pretty different - RB26DETT in an R33 4 door GTS4... :thumbsup:
Its pretty quick too.
Edited by Bullet32
These are the places.
For lower quality prints - Harvey norman is cheap
For Professional quality prints - Bica prolab (fyshwick) bit more $$
I'm guessing they might do a discount for group prints. Worth a shot...
That belongs to Me, Frink, Bluprint's mate Jeremy, its pretty different - RB26DETT in an R33 4 door GTS4... :D
This is relevent to my interests. Sounds awesome. Go the two-tone! :(
DOH!!!!!! SCOT!!!!!
He left his account signed in on my puter.....
I"LL be out this friday PM ME.... not scott.... Cheers
Frink - If you've got some time I could drop it to you another day. PM and we'll sort something out.
Cheers
J
So what happened to people being happy to donate some cash to our devoted camera man?
I need to know the best way to pool the cash together... C'mon people even a couple of bucks will do.
Count me in for the contribution... why don't you turn up on Friday and pass a hat around with the CD's?
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
