looking good mate, just out of interest when putting the dash led's in do you have to take out all the plastics around head unit etc?
edit : i would find out for myself but dont have car atm
Edited by 4Door_33GTS
yes you do need to remove that facia
I have an Apexi EL2 Analog Boost Gauge which has a blue light, I took a pic to compare one layer of Blue (301) over the clock. Tried to get them in the same pic to compare, came out quite dark.
Hey man, dash looks good!
Do you know if the light in the A'pexi EL2 can be changed? Iv never seen a black faced one lit up at night before, and now seeing yours, i was wondering if you can change it to white (not face, the illumination)
Cos the dash on my 33 is really white with brilliant red needles, so wanted the A'pexi gague to look as similar as possible :)
Ok so it doesnt look that white in the photo :P But im going to get either white LED's or the bulbs i use as parklights (soo white! :P )
Need to get rid of the poo poo yellow coming through the boost gague, and odometer bits :D
Has anoyne had experience with white LED's? Every time i get them they end up being purple :s Hence giving up.
Edited by gotRICE?
  • 5 months later...
It is not fantastic and my Apexi Boost Gauge isn't as blue as it used to seem against the new lights. The Clock and AC screen get darker when the lights are turned on. I think the colour would match better if they didn't dim. My AC screen is darker than the clock and I am thinking of trying the 301 Blue perspex for that to brighten it up.
I was thinking the I could find out which wire gives power to the AC Controls to let it know the lights are on and cut it but that would probably mean the buttons wouldn't light up. Maybe there is a resistor on the circuit board that would be easy to swap over over or just replace with another or plain wire.
I have also done the dash and a/c buttons with Dans LEDs, and got some blue gel/film and put in front of the lcd's, but yeah, the AC is darker, and very hard to read in the day w/ peak sunlight. The other two bulbs that you dont replace when doing the LED swap over, you reckon its possible to change with brighter bulbs? has any1 heard of any1 doing this? do want :laugh:
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
