looking good mate, just out of interest when putting the dash led's in do you have to take out all the plastics around head unit etc?
edit : i would find out for myself but dont have car atm
Edited by 4Door_33GTS
yes you do need to remove that facia
I have an Apexi EL2 Analog Boost Gauge which has a blue light, I took a pic to compare one layer of Blue (301) over the clock. Tried to get them in the same pic to compare, came out quite dark.
Hey man, dash looks good!
Do you know if the light in the A'pexi EL2 can be changed? Iv never seen a black faced one lit up at night before, and now seeing yours, i was wondering if you can change it to white (not face, the illumination)
Cos the dash on my 33 is really white with brilliant red needles, so wanted the A'pexi gague to look as similar as possible :)
Ok so it doesnt look that white in the photo :P But im going to get either white LED's or the bulbs i use as parklights (soo white! :P )
Need to get rid of the poo poo yellow coming through the boost gague, and odometer bits :D
Has anoyne had experience with white LED's? Every time i get them they end up being purple :s Hence giving up.
Edited by gotRICE?
  • 5 months later...
It is not fantastic and my Apexi Boost Gauge isn't as blue as it used to seem against the new lights. The Clock and AC screen get darker when the lights are turned on. I think the colour would match better if they didn't dim. My AC screen is darker than the clock and I am thinking of trying the 301 Blue perspex for that to brighten it up.
I was thinking the I could find out which wire gives power to the AC Controls to let it know the lights are on and cut it but that would probably mean the buttons wouldn't light up. Maybe there is a resistor on the circuit board that would be easy to swap over over or just replace with another or plain wire.
I have also done the dash and a/c buttons with Dans LEDs, and got some blue gel/film and put in front of the lcd's, but yeah, the AC is darker, and very hard to read in the day w/ peak sunlight. The other two bulbs that you dont replace when doing the LED swap over, you reckon its possible to change with brighter bulbs? has any1 heard of any1 doing this? do want :laugh:
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
    • ChatGPT is trash and lies about things I would not expect it to lie about considering many things it's wrong about are very easily verified with google. The S3 R33 GTR shares its steering wheel with R33 GTSTs of the same production year. Part number is 48430-26U17. I'm guessing you have to get it from a car that came with HICAS though, the ER33 is 48430-26U18, but the HR33 diagrams note that part number is still leather vs 48430-26U13 which is not leather-wrapped. They all use the same airbags, so if you need another one you can get it off basically any same year R33 or Stagea.
    • I'm going to run hard lines front to back in the future. That should help dissipate a bit more heat. If not, a fuel cooler might be next
    • No. The mark is with respect to the cam rotation. None of those things have altered it. When stationary, the cam position stays in sync with the crank position. It doesn't matter if you moved the head 4 feet up. Hence, that mark needs to stay exactly where it is.
