just filled the gearbox with shockproof and the sump with run in oil. Off to the workshop tomorrow for a new throttle cable and then the tune.
I dont know how anyone could afford to do this completely through a workshop. There have been literally hundreds of man hours poured in to it. Cant wait till next week. :huh:
https://www.sau.com.au/forums/topic/180200-its-done-tune-time/
  • Replies 115
Good Luck Noel :huh:
Im sure you'll tell us how you went tomorrow night... :)
Nah, wont be done till early next week Col. Hes still got some dicking around to do with the surge tank and a couple of other bits and pieces. I.m just happy to get it out of the garage. Every waking moment not at work has been spent on the car for the last couple of months.
Yeah I know that feeling mate...
scroll down to post #18 for an engine bay pic.
Mod list.....Everything. :nyaanyaa:
http://www.skylinesaustralia.com/forums/in...howtopic=176811
engine bay etc. looks awesome. good attention to detail.
what numbers are you hopeing for?
good luck
mick
Gee Noel, we should get our cars back at around the same time!! And I wish I didn't have to go through a workshop, but I don't have your ability and knowledge to call on. We should line up down the strip and you can flog me.... just not by as much as you think!!!
For those that asked heres a summary of the mod list. Starting from the bottom.
High energy gated, baffled and large capacity sump
Jun oil pump
jun drive collar
Eagle rods,
Cryoed crank
OS giken pistons
tuffman harmonic balancer
Massive headwork on both inlet and exhaust plus combustion chamber mods
oversize exhaust valves.
Fearia valves and heavy springs
Arp head stud kit
Steel head gasket
Complete conversion to solid lifter operation with tomei solid cams.
Head to sump oil drain back
Tomei restrictors
Splitfire coils
Greddy plenum
Fuel rail
650 cc injectors
80 mil throttle body
Spool cam gears both sides
Aero fuel regulator
surge tank with bosch pumps in tank and external
Predator 3 mil stainless high mount exhaust manifold
Garret 35/40 turbo ex. gate
Tial 44 mil ex gate
GFB bov (plumb back and atmo)
600x300x100 front mount with custom piping
Oil cooler and filter relocator
Q45 AFM
Blitz pod underguard mounted
baffled catch can washer bottle combo
Large alloy radiator (ARC)
Gates radiator hoses
Gates drive belts
Braided turbo oil and water lines
braided clutch line
Braided fuel lines
Braided brake lines
R33 Vspec brembo brake upgrade
33 vspec master cylinder
Pro comp power fc with data logit and launch control
Profec boost controller
C's short shifter
Greddy lightened flywheel
Custom 3 and 1/2 inch exhaust from the turbo back inc. cat.
Button clutch and high clamp pressure plate
Oil gallerys have been chamferred, Bottom end is fully balanced.
Theres so much more that i cant recall atm but i am sure you get the gyst of it. I made the valley cover and a local did the polishing of the covers, turbo housing etc.
Still to come is some suspension, I have adjustable whiteline swaybars on board atm but i want to upgrade the shocks and get some adjustability into the suspension geometry as well.
Holy shit Noel that list is awesome, great job mate. It will be a weapon by the sounds of it. Cant wait to see it.
Havent seen you around for while now i know were you have been.
What exhaust housing did you go with.
.82 sub. When are we gonna see u at the bank again bud?
I would say about a year :P . I have to baby it it for a while now. Taking up a new job in October and will be taking a massive paycut for about a year. Will talk to you later about that.
ill pick on your car noel. Get rid of that stupid silicon 90 degree bend and weld an ally 90 on there in its place...im sure ive told you that before. It will burst right where the heat radiates from the silly s/s manifold you got :(
Apart from that it all looks very bling and respectable mate...excellent work and build!
Edited by r33_racer
ill pick on your car noel. Get rid of that stupid silicon 90 degree bend and weld an ally 90 on there in its place...im sure ive told you that before. It will burst right where the heat radiates from the silly s/s manifold you got :mellow:
Sif Bling! Rice you tool. When it bursts you can be the first to say "I told ya so ya silly old fart" :(
