well im doing a nice simple build of my rb26dett, its pretty much fresh rebuild of an r32 motor, everything is stock but im running a t3 60-1 single turbo upgraded walbro fuel pump, adj. fpr 24x12x3 front mount intercooler and 3 inch exhaust. im gonna use an safc to due a slight tune. boost in the range of 15psi. im looking for 350hp-400hp will that get me there? if not where would i be around with this setup?
thanks!
https://www.sau.com.au/forums/topic/180262-help-me-guess-output/
As with all the other threads you've started
what is the spec of the turbo.
It is impossble to help you if you wont help yourself and provide the details of the turbo being used!
And i still dont know why your skimping on a few hundred and not going with a tried and proven turbo from a reputable dealer
what ecu are you running in that S13 chassis and the rb26? obviously a std GTR .. but why go SAFC instead of standalone r32 GTR pfc ?
you want to get 400hp by only tweaking fuel? doesnt sound like it will make the most of your setup.
