By Demand by a few guys/girls in Newcastle, I thought i would start this thread for all Newy Owners to organise A Cruise.
I am proposing a cruise for either the saturday 25th or the sunday 26th August 2007 for my 23rd birthday. It will be the last day my car will be on the road as i have been defected and thought i'd do a cruise for my Bday as well at the same time as my car will be off the road till i can save up and get everything done for an engineers certificate etc etc.
So....
Anyone whos keen please let me know what day you prefer and put your name down below.
MEET AT: DIXON PARK BEACH CAR PARK
WHEN: 10 AM , 25TH or 26TH AUGUST 2007 .
THEN LEAVE AT 10.30AM AND CRUISE UP TO SALAMANDER BAY AND GET LUNCH AND CATCH UP ACCROSSFROM SHOPS/SHORELINE
SO ALL YOU SKYLINE OWNERS COME OUT FOR MI BDAY AND A CRUISE TO THE BAY.
IF ANYONE WANTS TO CALL ME MY NUMBER IS 0405 416 496
CHEERS KIER.
Edited by yye-33w
https://www.sau.com.au/forums/topic/180286-newcastle-thread/
i'd be keen for the 25th,if i've got my car back going to get front bar sprayed and a few other things fixed up,have any of you guys in newy (or maitland would be better) that have put one of those t-piece boost controllers on and would be able to show me one day?
    • Gas MIG for learning, I was able to weld up some nice 1.6mm tubs so you can do thin stuff easily enough. Then moved on to thick caliper adaptor brackets with the same machine, all good.  Arc/Stick is great for dirty garden work etc, but Gas MIG for starting on car stuff.  Jump on the NCR FB page and search ATP Tubs or GKTech caliper adaptors for pics/info. I'm no pro but it wasn't hard to learn. Be willing to grind and go again though if it's cold etc.
    • That's not a bushing!
    • Oh and I got myself a grandpa spec dash mat.
    • Ok, so first round of maintenance done. I didn't get much history with the car but I know it was well looked after. That isn't enough for me though, so ...  I had to do the oil filter housing gasket. It was leaking a lot, and also as part of that I did the anti-return valve and the VANOS oil line (from HEL).  But, then I got hit with the while-ya-in-there's. Did both accessory and A/C belts, tensioners and pulley. The accessory belt that came off had a huge hole in it, like somebody hung it up with a nail. The pulley and tensioners seem ok, so I'll keep those just in case. I did water pump and pump pulley. The water pump had a small bit of play so timing was good.  I also did fan clutch. I don't know how to test the old one but between the water pump and the fan clutch the car is running a little bit cooler (not much ~2 - 3 degrees maybe) so good result. Unfortunately the thermostat and housing didn't turn up in time so I'll shelve those. I have no concerns at all on the current ones.  Then I spent what seemed like 40 days and 40 nights bleeding the air from the cooling system. She also got new air filter, fuel filter and did a Mobil 1 change with oil filter. Hilariously, not an hour after telling my wife how proud I was of myself to be going slowly and meticulously and making sure everything was torqued and nothing missing I went and started it without the oil filter in. The car complained immediately of no pressure and after only a few seconds I turned it off and discovered a shit tonne of oil on the driveway. Sigh. I've driven it since and thankfully doesn't seem to be any problems. AND THEN during the test drive a ratchet extension fell into the battery area in the boot and JAMMED right next to the positive terminal and the car body. Like, just touching it made sparks and it was jammed in there. So, almost killed the engine and then almost burned the car to a crisp. Good start. This was the rails under the splash guards. So stoked, she's straight as and super clean. No rust anywhere. There was a heap of caked dirt that I removed but otherwise looked great. All 4 jacking points are perfect.   Next I want to service the gearbox. Sometimes it's a little reluctant to shift up and I'm hoping a fluid change will sort it. I also have 4 new rear subframe bushes. They're as big as a toddler. I'm renting a tool to help put them in. I can't wait for this because its a bit crashy back there at the moment.
    • Remember when those donkeys kept using freedom units and smashed that satellite to bits on the moon? NASA has their brain switched on and uses the metric system.
