After loads of searching i couldnt find anyone that has mentioned this before so im stumped
I've got oil, or what looks to be oil forming droplets on the end of the front tow hook
and in the space underneath the battery, in front of the wheel arch theres a build up of oil+dirt.
If it was water and dirt it would have dried up and be left with just dirt but it always seems to be wet around there
i dont know if its engine oil or not but i dont have any oil leaks that i know of and the dipstick is never low when i check it.
Plus where the "leak" is, its a little far from the engine.
I dont think it's coolant either since my radiator is still full from when i filled it a few weeks ago. and the liquid isnt green.
Is there anything around that area that could be leaking?
I cant for the life of me find where its coming from
Edit: see post #7 also
Edited by r32woohoo
https://www.sau.com.au/forums/topic/180327-oil-coming-from-unknown-hosespipes/
Hmm looks like everyones leaning toward powersteering lines
my power steering doesnt feel any different though :S
ill have a closer look when the suns up
and yes did you just use any type of hose?
Well i seem to have narrowed it down to some pipes/hoses
only problem is i dont know what they're for or where they go
In my 32 they're the metal pipes in front of the radiator that sit on top of that black bottle type thing for the air con
You can see them circled in red. (not my engine but i dont have a photo of mine)
Since the power steering stuff (pump and reservoir) is on the other side of the engine i dont see how it could be related to that.
If i was to take a guess i would say they're somehow gearbox related? to cool the oil and such?
But ive never heard of a manual transmission oil cooler :whistling:
That's the power steering cooling line / pipe. Follow the pipes back into the engine bay and you'll see that the connect to hoses ( with clamps ). Make sure the clamps are tight and in good working order. Then check the hoses them selves for any signs of leakage.
To test the area for leaks, make sure your power steering fluid is at the correct level, then ( with the engine running ) get someone to operate the power steering from lock to lock while you hold a decent size piece of cardboard near the suspect area and look for any pressure spray / leakage ( don't use your hands because pressurised hydrualic fluid "could" wind up going through your skin & into your blood stream ).
See how you go with that :)
Its always power steering leaks on my car :)
booster were they the high pressure fitted hoses? who made them up for you?
No, just 10mm return lines, two near hicas solenoid and in and out of the cooler loop.
I previously paid $66 to have Enzed repair the high pressure line on my son's 32 when the hose section was cut in a crash.
Ahh yeah OK the high pressure hoses I found were expensive, was hoping for a cheaper alternative.
r32woohoo I think it was already answered, they are still power steering lines, they have a kind of crappy cooler from factory which sits there - there are basically a bunch of cooling fins on the pipe to reduce temps. On the 32 its even worse, power steering lines are everywhere (resoviour, steering rack, hicas solenoid, cooler and righ tto the back of the car). They are high pressure and old so they tend to leak a bit
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
